Wooden Block For Clutch
   / Wooden Block For Clutch #1
dlockh4258
Lexington Kentucky
Kubota B2910
On my new B2910 Kubota gave me a wooden block for the clutch. Could someone explain the purpose of having the clutch engaged while in storage using this wooden block.
   / Wooden Block For Clutch #2
It is used to keep the clutch plates apart, thus keeping them from rusting together which causes difficulty when trying to stop the transmission to get into a gear or to change to a different gear. More of a precaution for long storage than for normal storage and use of the tractor.
   / Wooden Block For Clutch #3
<font color=blue>More of a precaution for long storage than for normal storage and use of the tractor. </font color=blue>
Can you give me a rough idea of what "long" means in this context? For example, if we took a two week vacation, would that be long enough to warrant blocking the clutch pedal? Or are we talking months or more?
I have a JD 4300 with manual tranny, so wonder if this is prone to the same problem? I assume a clutch is a clutch, so probably yes?
Tks,
Bob
   / Wooden Block For Clutch #4
I would only do it if it were a "mothball" situation. Long term meaning a year or more. Some probably wish they had done it when a tractor sits over the winter in cold storage with the heating and cooling cycles causing some condensation. I wouldn't even consider it for a two week vacation type thing. (Just my opinion though).
   / Wooden Block For Clutch #5
<font color=blue>I would only do it if it were a "mothball" situation. Long term meaning a year or more.</font color=blue>
Thanks, beenthere. Just curious.. is there any downside to blocking the clutch? I mean, won't the spring you're pushing against when you depress the pedal begin to lose its spring, or anything like that?
   / Wooden Block For Clutch #6
Trev;
I put the block on my clutch in the winter if I don't use it for a week or so. I only use the tractor in the winter for snow removal, so it can sit for few weeks easily, especially towards the end of the winter.
I figure that, with everything wet after clearing the driveway, if it sits in the garage (unheated) for a few weeks, rust would easily start to form, albeit minor. Sticking the block on lets the plates "air out", in my mind, at least.
2007 Freightliner Columbia 120 - Class 8, 6x4, Mercedes MBE4000 Diesel (A52748)
2007 Freightliner...
2007 FREIGHTLINER M2 26FT CDL REQUIRED BOX TRUCK (A54607)
2007 FREIGHTLINER...
2013 PETERBILT 365 T/A DUMP TRUCK (A51406)
2013 PETERBILT 365...
2006 INTERNATIONAL 7400 6X4 DUMP TRUCK (A52706)
2006 INTERNATIONAL...
JCB 270T T4 SKID STEER (A52705)
JCB 270T T4 SKID...
1996 FORD F SERIES DUMP TRUCK (A51406)
1996 FORD F SERIES...
