/pine
Super Star Member
- Joined
- Mar 4, 2009
- Messages
- 12,450
Question about a wood stove a friend has...
...It's a home made stove that has a flat 1/4" plate door that just overlaps a flush opening...with welded on gate hinges...there is no space (offset) for a typical stove door gasket...plate door fits flush against plate opening with marginal overlap...
The stove works well enough but when it gets hot the bottom left (unhinged) corner of the door warps out leaving a big gap that effects the dampening ability...
Would welding some pieces of heavy angle iron across the door be enough to stop the warping?
Is adding a 1/2" return to either the door edge or the opening a worthy option?
