wood splitter problems
/ wood splitter problems
Thanks for all the feed back guys, I took back the pump today and exchanged it for a new one. I hope this solves the problem.
Thanks again /forums/images/graemlins/smile.gif /forums/images/graemlins/smile.gif
/ wood splitter problems #22
Deerlope, you don't know me, but I've enjoyed reading your posts. I just want to say that I hope your wife is doing better and you take care of yourself too as you will be no good to her if not. Best of luck, John
WooHooo!!
the new pump solves the problem. I started her up and jammed a block of wood in her teeth.... 3000 lbs on the guage. The other pump wasn't shifting into the second stage afterall. /forums/images/graemlins/cool.gif
I adjusted the relief valve on the control down to 2300 lbs and it splits like snot now.
Thanks guys.
/ wood splitter problems #24
Mr Dean, If you are happy with 2300psi OK but you can set that at 2500psi and still be safe if your welds are good and your steel is heavy enough. Glad to hear that you are happy.
Case-IH 180 Magnum (A57148)
Case-IH 180 Magnum...
WOOD GRABBER FOR MINI EXCAVATOR (A58214)
WOOD GRABBER FOR...
2018 Ford F-150 4x4 Crew Cab Pickup Truck (A59230)
2018 Ford F-150...
2008 Mercury 25HP 3-Cylinder Boat Motor (A59231)
2008 Mercury 25HP...
2021 MULTIQUIP WHISPER PORTABLE AC GENERATOR (A59823)
2021 MULTIQUIP...
2017 Freightliner M2 106 AWD Terex Hi-Ranger 5TC55 55ft. Insulated Material Handling Bucket Truck (A60460)
2017 Freightliner...
