wood spliter/remotes?
   / wood spliter/remotes? #1
griz
sw missouri
Case DX 40 8/1/03
Hello everyone, I was wondering if you need rear remote h. vavles to run a wood spliter, or do they vary. I'm in the process of getting a approx. 30hp tractor and wondered if I could every find the use for extra remotes. Thanks, Griz
   / wood spliter/remotes? #2
If your getting an FEL then you can just use that for your splitter. The remotes were very expensive to add to my tractor so I just use the ones for the FEL.
Steve
   / wood spliter/remotes? #3
Kubota's remotes are the most expensive to add that I have found. Most are around $200-300.
Some logsplitters use the tractor hydraulics (like TSC's), either the remote or the FEL connectors and are $550-575. Another I saw has a PTO pump, but it cost as much as a better self-contained unit.
The rears will come in handy for a hydraulic top link (which I am thinking about adding this year) or a tilt cylinder. I am sure there are other uses.....
Mark
2009 IC Corporation PB105 Passenger Bus (A51692)
2009 IC...
2018 HINO CONVENTIONAL TYPE TRUCK (A52472)
2018 HINO...
2025 Mower King SSECAG-Y (A50123)
2025 Mower King...
2017 Ford F-450 XL (A50123)
2017 Ford F-450 XL...
2023 MAXEY G8X 26FT TILT BED GOOSENECK TRAILER (A53426)
2023 MAXEY G8X...
1265 (A50490)
1265 (A50490)
