wood chips for temporary road
   / wood chips for temporary road #1
horses2
Bronze Member
Westminster, Md
Kubota M471D
whats everyones opinion on using wood chips to put down as a temporary surface over a path thru a hayfield? it would be temporary as a realigned road will be built later on, but for the next year or so, i need to have this path usable, but dont want to put stone down as it will become part of the field after the new road is built.
I was thinking 3/4 inches of wood chips would give a good temporary surface that would just decompose after i am done,m and wouldnt hurt a discbine or mower.
FYI, I have PLENTY of chips from a clearing project.
Thanks,
   / wood chips for temporary road #2
It really depends on what the soil is like and how wet will it get. My thinking is that you're wasting your time trying to use chips. They won't lock together or support a load like gravel will, and once they get wet, they will just become part of the mud. If the area is fairly solid and well drained, it might give some advantage, but I can't really see what that would be.
   / wood chips for temporary road #3
For this woodchips seem ideal. Ordinarily they gradually destabilize traversed ground by becoming imbedded by traffic, and then acting as a sponge while they decompose. Stay on high well drained ground and this could be perfect as you bring the area back to hay.
   / wood chips for temporary road #4
I'm not sure there is any benefit to a "wood chip road".
As mentioned, they don't interlock nor do they support any weight at all.
They do hold moisture that might firm up a sand lot until it did dry,
Chips would keep some of the dust down, and of course they look great to define the path.
I wouldn't use chips here in VT, but I would compost them and spread that on the temporary path when it is no longer needed. That would bring back good growth quickly.
   / wood chips for temporary road #5
I have used wood chips to firm up a boggy path leading out to the fields. Prior to that, repeated trips through the area kept churning it up and making it worse. The chips did a reasonable job, stayed In place better than I thought, and cut the dust after the area dried out as the weather warmed. They were however, a temporary solution, as they eventually became pulverized by the tractor, and disappeared into the soil. If you have a good supply of chips, and the cost is nil, I wouldn't hesitate to use them, knowing you may have to add more now and then to maintain the surface. Unlike gravel, they will eventually disappear with no potential harm to your cutting equipment.
   / wood chips for temporary road #6
wood chips will work. find out where they are clearing power lines and see about where they put the grindings
   / wood chips for temporary road #7
I hope you meant 3"-4" of wood chips and not 3/4" of an inch.. But ya, go ahead and use them.
   / wood chips for temporary road #8
As long as your soil is not so wet that they rot too quickly or you have enough rain that they wash away, the ones from line clearing work just fine. We have used them for years.
   / wood chips for temporary road #9
A wood chip road with those small chips isn't going to be much of a road. Pathway yes, roadway no.
A note to throw in to the discussion, horses2. dunno if you intend on grazing your horses in here temporarily, but I would point out to you and others, not all wood chips are livestock, horse, or cow friendly. There are numerous sources on the internet from horse owners and vets. Toxicity can be absorbed via browsing or standing on them.
Where I live, I will only use douglas fir, pine or cedar or alder chips. Black walnut, black locust, stone fruits, all are a no no.
   / wood chips for temporary road #10
I made a temporary road out of chipper chips. It worked pretty good. I dump the leafed I rake off the yard in my trails. That works pretty good to keep the mud down. They neither one worked as good as gravel, but they were both free.
2012 TIGER MFG ACID TRAILER (A45046)
2012 TIGER MFG...
2022 Chevrolet Traverse LT SUV (A42744)
2022 Chevrolet...
2007 KENWORTH T800 (A45046)
2007 KENWORTH T800...
2018 Ford Transit Z50 (A44501)
2018 Ford Transit...
Honda Rancher E5 ATV (A44572)
Honda Rancher E5...
1998 Volvo VN Truck, VIN # 4VA7BBJF2WN759933 (A44391)
1998 Volvo VN...
