wont stop
   / wont stop #1
jerryh
I need some help please bobcat wont stop traveling when you let off it also travels to the right thanks Jerry
   / wont stop #3
Are your hydrostatic pumps controlled by a cable or is it hyd controlled? Something is binding causing the lever not to go to neutral.
   / wont stop
sorry about not putting enough info i think i found the problem it was the
in the linkage the plate above the motors has some stops and it had come loose and a rubber bushing was worn in the linkage
thanks a bunch
Jerry
Engel 20' Boat (A50121)
Engel 20' Boat...
2015 Volkswagen Passat SE Sedan (A50324)
2015 Volkswagen...
2013 FREIGHTLINER CASCADIA SLEEPER (A52576)
2013 FREIGHTLINER...
2009 Peterbilt 384 T/A Wet Kit Day Cab Truck Tractor (A50323)
2009 Peterbilt 384...
2013 Cadillac ATS Sedan (A50324)
2013 Cadillac ATS...
2019 FREIGHTLINER M2 26FT BOX TRUCK (A52577)
2019 FREIGHTLINER...
