Won't start
   / Won't start #1
murph1
Ohio
MF-135 DK-40se Ventrac 4500
I went to start my tractor yesterday and all I got was a click click click.
I charged the battery and now I get a louder CLICK CLICK CLICK.
Thanks for any and all help
Murph
   / Won't start #2
Ok - I'll be first to start - How old is the battery and your sure it's good .
   / Won't start
7 years and its at 10.30 volts. I charged it last night too
   / Won't start #4
Voltage is too low for it to start. Try another battery. Take yours in and have it load tested. I suspect it will fail. Also check your battery cables for corrosion at the frame for negative, at starter for positive. And cut back the insulation a bit to see if there is any corrosion under the insulation. Shiny clamps where they connect to the battery too. Report back, Murph.
   / Won't start
Should I use Interstate again?
   / Won't start #6
You got 7 years out of it, and I bet it had no maintenance.
   / Won't start
It was on a smart charger all the time. You lose your bet
   / Won't start #9
I have had very good service out of many interstate batteries over the years..
   / Won't start
I seemed to have misplaced a cell.
2006 Cat 963C Crawler Loader (RIDE AND DRIVE) (NICE) (A50774)
2006 Cat 963C...
2019 Freightliner 122SD, Cummins X15 (A52384)
2019 Freightliner...
2012 Wells Cargo CEW202 24ft T/A Enclosed Trailer (A50324)
2012 Wells Cargo...
New Kivel Walk Behind Pallet Forks (A50774)
New Kivel Walk...
2008 Freightliner B2 School Bus (A51692)
2008 Freightliner...
2017 Ford Escape SUV (A50324)
2017 Ford Escape...
