wont start
   / wont start #1
customshey
adams ma
bolens h1502
i have a h1502 bolens dad ran it out of fuel now it wont start bleed all the lines doesnt seem to be getting fuel to the injectors
   / wont start #2
Sometimes when you run them dry you suck up all the gunk at the bottom of the tank, and plug up the filter. Start at the tank outlet and make sure fuel is flowing. Then follow the lines from there all the way to the injectors and check fuel flow at each possible problem area. I'm not sure how that engine is set up, but generally speaking, check fuel flowing out of the tank, then out of the lift pump, then out of the fuel filter, then out of the injector pump (or just at the injectors.
Regardless, I'd put a new filter in it because there's no way of knowing what came out of the bottom of the tank.
2011 Retesa CT7622 150 Vacuum Tanker Trailer (A52377)
2011 Retesa CT7622...
2009 MACK GRANITE (A52472)
2009 MACK GRANITE...
2016 Club Car Carryall 1500 4x4 Utility Cart (A53424)
2016 Club Car...
2014 Jeep Patriot SUV (A53424)
2014 Jeep Patriot...
2012 PETERBILT 587 SLEEPER (A54313)
2012 PETERBILT 587...
