Won't start
   / Won't start #1
soccercoach
Nicholasville, KY
Mahindra 5005 D1
Have a Mahindra 5005 D1. Have had to wiggle neutral lever between High and Low to get it to turn over. Now with a new battery it won't turn over at all. Is there a safety switch I need to change? Easy to change???????? Suggestions.............
   / Won't start #2
soccercoach
Easy to find, easy to replace. The parts schematic shows that it screws into the right side of the shift top, near the base of the main shifter. It screws directly into the housing, and comes with a short, plug in harness. Hope this helps!
   / Won't start
soccercoach
Thanks. It will.
KJ 12'x20' Single Garage Metal Shed (A50121)
KJ 12'x20' Single...
2015 Ecoline 7 Ton T/A Equipment Trailer (A50323)
2015 Ecoline 7 Ton...
NEW Woods Reverse Rotation 5ft Tiller (A52748)
NEW Woods Reverse...
CFG Industrial Q.A Hydraulic Breaker (A50121)
CFG Industrial Q.A...
2013 Ford F-150 4x4 Crew Cab Pickup Truck (A50323)
2013 Ford F-150...
2012 DRAGON 150BBL ALUMINUM VACUUM TANKER TRAILER (A52472)
2012 DRAGON 150BBL...
