Oil & Fuel Wont run
   / Wont run #1
carman98
Girard,Pa
Mitsubishi 24Hp 4x4 diesel
I was brushhogging, ran out of diesel, Now it wont start. seems like dirt in the injecter pump.What would be the best thing to do.
   / Wont run #2
Bleed the air out
   / Wont run
Thank You. I'm a little dumb when it comes to traxtors. How do I bleed the air our correctly? Thanks
   / Wont run #4
Bleeding procedures differ according to the make/model and should be described in your owner's manual. If you don't have a manual, post your question in Mitsubishi/Satoh with a descriptive thread title.
Good luck.
Steve
   / Wont run #5
crack the fuel line at the pump and crank the engine when you have fuel there tighten it and crack the fittingsat the injectors crank it when you get fuel close them it may start we had to tow mt neighbors ford tractor after we blead it and it started my farm pro has a built in hand pump to blead the sys
   / Wont run #6
There should be a bleed screw nut/bolt close to the filter. There may be a little lever for a manual priming pump . Pump that till fuel comes out of filter . Tighten filter and start . Do not fu44with fittings at pump or injectors .
UNUSED FUTURE 7T HYD THUMB CLAMP (A51244)
UNUSED FUTURE 7T...
SHOP MADE  MANIFOLD TRAILER (A50854)
SHOP MADE...
2019 Bobcat T770 Two Speed Compact Track Loader Skid Steer (A50322)
2019 Bobcat T770...
2016 Ram 5500 4x4 Bucket Truck (A50323)
2016 Ram 5500 4x4...
Koyker Loader DoubleTine Bale Spear - Versatile for Round and Square Bales (A52128)
Koyker Loader...
2014 Mack CXU613 T/A Day Cab Truck Tractor (A50323)
2014 Mack CXU613...
