Loader won't go into float mode
   / won't go into float mode #1
gary d
Amelia Courthouse, Virginia
I have a 1532 w/ a loader. The loader won't go into the float mode.
When I lower the bucket it lifts the front end if I keep the joystick engaged.
Tried pushing real hard to get past the point that it should engage the float, but no luck.
Anyone know if there is an adjustment that can be done on the joystick?
   / won't go into float mode #2
I'am not sure what your valve is like but you may have to remove the cap on the back side if the valve and give it a good cleaning.It could have rust /dirt/crud build up that's preventing you from pushing the lever in far enough to activate the float.Hope this helps.Larry
I removed the cap and cleaned and lubed and re-assembled and it works perfectly now. Thanks for your help.
Didn't see anything wrong in there, so I guess it just needed a good cleaning.
2012 Hino 262 Rollback Tow Truck (A50323)
2012 Hino 262...
1/2 HP 300-1200 RPM Drive Motors (A47384)
1/2 HP 300-1200...
New Idea Manure Spreader (A50515)
New Idea Manure...
2020 Lincoln Naultilus SUV (A50324)
2020 Lincoln...
UNUSED KIVEL HANG ON WHEEL LOADER PALLET FORKS (A51244)
UNUSED KIVEL HANG...
