Wont crank!
/ Wont crank! #1
coyoteson1
fluvanna,virginia
cub cadet 1450
I have a cub cadet1450,last cutting sas on while attempding final cut, my tractor shut off. I'm not much of a mechanic but my frist thought was to check the carb for gas.All good there so then I checked for spark, none plus at this point I noticed my ignitieon switch wasnt working.Replaced my switch still nothing any ideas on what my problem is?
/ Wont crank! #2
#1. Is your battery still charged..?? If it's not generating, then it could have ran the battery down.
#2 Battery connections. Could be loose, or corroded. Usually the ground.
#3 Safety switch for pto, or under the seat may be bad. A test light should let you know pretty quick, if you are getting juice back to the ign. switch.
/ Wont crank! #3
"won't crank" ?
Do you mean it won't turn over when you turn the key or do you mean it won't start when the starter is turning it over?
Technically "won't crank" means the starter is either not engaging or the engine is locked up tight and it won't rotate. But regionally, some folks use those words if the engine is spinning but not starting.
/ Wont crank!
Thanks DJ54 will be pulling the battery as soon as I get home. Whats a good method for checking pto switch?
/ Wont crank!
@ Ford Tractor, from the key it does nothing but with switch on and a jump from the starter it spins ovet fine just doesnt start.
/ Wont crank! #7
Its the spark. What makes your spark?
larry
/ Wont crank! #8
You did disengage the mower.., right..?? If so, there should be a safety switch under the seat. It should shut the engine off, when the pto is engaged, if you get off the seat.
A simple test light should let you know if your battery has some charge, or you are getting power to that switch. If you find power to it, check the other side, which should go to the ign., and see if power is going through the switch, with pto disengaged, with the ign. switch in the run position.
If there is a plug on the safety switch, you can run a jumper wire on the plug side, to see if the switch is bad.
As Ford Tractor mentioned, to some of us.. "not cranking" means the engine is not turning over. Even jumping it from another battery, I do believe the safety switch will kill the ignition.
The again, the plug may have simply unplugged itself from vibration. Stranger things have happened...!!
/ Wont crank!
I have looked and looked under my seat and there is no type of switch underneath. Today I pulled the battery out and fully charged it,removed ground cable and cleaned connection area as well as cleaned -and + cables. Double checked my installation of ignition switch and still it will not turn over by key and there is no spark from the plug(not firing).
/ Wont crank! #10
I did not realize it is a hydro, and has electric pto. So hopefully if you follow this link, it will help you with your wiring, switches etc. It is at Cub Cadet.com, and this link shows you wiring diagram for the ignition & starting.
ARIPartFinder
Here is the link to the main website, for Cub Cadet:Riding Mower, Lawn Tractor, Zero Turn Mower
I did check out the seat assy., and it does not show a safety switch. Possibly, the electric pto, and neutral safety switch are tied together.
I also googled a service manual for the 1450, and reprints show IH on the cover, so by that, I'm assuming it is a '78 model or older..??
I would follow the wire, off of #14 in the diagram, which I'm assuming is a solenoid, that goes to the neutral safety switch. Hard to say where it is, but shouldn't be that hard to trace. Check to see if you have power through the neutral safety switch. Then, if you have it at the ignition switch.
Note, #6 in the diagram is a 10 amp fuse. Definitely check that, as it is tied into the harness.
At least you have now a link to Cub Cadet, and if you go to the far right at the top and click on parts & service, select your model on the next page, then click on, select an assembly, you can find any part, at least in the diagram, and part number for your tractor.
/ Wont crank! #12
Replace the spark plug. Many plugs when viewed/tested will make tons of spark but they say under pressure in the combustion cylinder they will not. I had 2 plugs do that to me last summer in a water pump and a rototiller. It is only $3 for a plug and good maintenance anyway.
/ Wont crank! #13
Symptoms point to a safety switch. Typical places are the blade on/off switch, parking brake, transmission neutral etc.
Looking at the wiring diagram there are at least 2 "safety" switches on you mower. Make sure your hydro pedal is in neutral and your mowing blades are off. You would be surprised how often that happens (controls in wrong position to start)
2021 Mercedes-Benz Sprinter 4500 Modified Food Catering Van (A61574)
2021 Mercedes-Benz...
58in Hydraulic Side Shift Forks Skid Steer Attachment (A61572)
58in Hydraulic...
2021 POLARIS PRO XD 4000D UTV (A64280)
2021 POLARIS PRO...
UNUSED WOLVERINE (A64281)
UNUSED WOLVERINE...
(2) 380/85R30 TIRES W/ 8 LUG RIMS (A64280)
(2) 380/85R30...
2013 Atlas Copco XAS 400 JD7 Portable Air Compressor 125 PSI - Trailer Mounted - Tier 4 (A63689)
2013 Atlas Copco...
