jsg
hello all
thank you for the great information.
for 2009, i plan to increase my acreage under cultivation from 4 to at least 10 acres of vegetable and flower production.
currently i am farming these 4 acres and maintaining a 20 acre woodlot with a 350cc atv (which is also what i am using to farm)
i find i am lacking in 'pulling power' for tasks such as discing and rock (big rock) removal...i cut and buck trees in the woodlot - transportation in an atv pulled cart is not a problem.
i find i am also lacking in a proper snow removal system.
there are small nuisance trees at various spots on our property which i would like to remove
drainage trenches need to be dug and maintained (surface drainage, not tile drainage)
i have been leaning towards the lk3054, primarily because of what i thought was an 'integrated tlb' and its small size (width) is similar to the atv so as to maintain my current farming methods of bed making etc..(as well as fitting the woodlot trails)
also, i felt it would be more suited to other more landscape-type jobs during times when the field needs less mechanical attention.
however, being on 80 acres (50 of which are rented out annually), of which i expect to use 25 between now and 2011, 30 hp seems small.. not to mention that the ground clearance is less than what i would want for vegetable farming.
older tractors are selling for relatively high prices, i am not very mechanically inclined, and in general, i would simply prefer a newer investment.
the price i was quoted for a lk3054 tlb was about the same as for a dk40se without a backhoe
so far the only test drives i have had were on a lk3054 and two bransons (3510 and 4720)
knowing that only i can answer this question, i still am asking the group here if a backhoe (as part of a compact, sturdy unit) and smallish size is worth not having 10 more hp, quick attach bucket, extendable 3pt arms, higher loader capacity, and more ground clearance..?..
would a backblade (for drainage ditch), and a toothbar (for loosening soil around stumps and lifting rocks) be suitable and cost-effective substitutes for a backhoe?
i think i have answered my own questions, but feel free to reply if you have read this far..
