Won’t start
   / Won’t start #1
Rdf59
Mahindra emax 22
I have a Mahindra emax 22 and it is difficult to start. It has just started this. It will turn over great and try to fire but most of the time it won’t start. The light on the dash flashes 3 times slow then 4 times fast. Any ideas?
   / Won’t start #2
flash codes for EMax 22
11 Actuator Overcurrent
12 Actuator Open Circuit
13 Actuator Position Sensor (short to ground)
16 CPU Configuration
17 CPU Failure
18 CPU Power Supply (5V-3)
21 DOUT 1 (CEL) Over Currant or Open Circut
28 DOUT 8 (Glow plug Relay) Over Currant or Open Circut
31 Engine Coolant Temperature Sensor High or Lo
32 EEPROM RW Failure
33 High Battery Voltage (Over16.2V for 60 sec.)
34 Magnetic Pickup Sensor
35 MAP Sensor Hi or Lo
41 MAP Power Supply (5-2)
42 Engine Over Speed
43 Engine Over Temperature
44 Actuator Position Sensor Hi or Lo
   / Won’t start
Thanks, I appreciate it!
2011 Ford Transit Connect XLT (A50323)
2011 Ford Transit...
2018 FREIGHTLINER CASCADIA TANDEM AXLE SLEEPER (A51219)
2018 FREIGHTLINER...
28013 (A50322)
28013 (A50322)
Danuser 3 pt Post Hole Digger (A50515)
Danuser 3 pt Post...
2016 POLARIS RANGER ETX EFI 00HC RTV (A51243)
2016 POLARIS...
John Deere 693 Corn Head (A50514)
John Deere 693...
