WOAH! Won't Start! What have I done?
   / WOAH! Won't Start! What have I done? #1
slhilbert
Bronze Member
Noblesville IN
Massey Ferguson 135
Well, I am back and things have gone from bad to worse.
I took the carb off, cleaned it, put it back on. Same result as before.
I bit the bullet and bought a new carb, wouldn't hardly even start. Just putter and die.
I played with the timing at the distributor cap by rotating it, didn't help.
Took old carb apart again, adjust floats cleaned it, etc. Still nothing.
Replaced the fuel lines and sediment bowl (Getting desperate at this point).
I checked spark and I have a good spark on all three wires.
I feel like I maybe have messed up the timing really bad because at this point I can't even get it to pop off really.
I decided to cut the fuel line off and just try starter fluid as I thought that would tell me if the carb is having an issue. I did this and the starter fluid is just blowing out the exhaust. I might get one really loud back fire and that is it.
I am attaching a short video for you to see what I am trying to describe. PLEASE HELP! AHHH!!!! ;)
Thank you,
Stuart
   / WOAH! Won't Start! What have I done? #2
First, make sure the plug wires are connected to the correct distributor port. Then I would remove the distributor cap and clean the points and condenser; maybe replace both. Then check the plastic distributor cap closely for any hairline cracks and corrosion on the contacts. Replace if needed. Also check the rotor cap for corrosion at the contracts. Plug wires are another possible problem, if old and faded.
   / WOAH! Won't Start! What have I done? #3
The backfire says you have the timing wrong. Ditto what @kirkawilson says.
   / WOAH! Won't Start! What have I done? #4
Google "static timing an engine". Following the procedure should get it close enough to run. Have you looked at the spark plugs? The white smoke makes me think it may be flooded and the plugs are wet.
   / WOAH! Won't Start! What have I done? #5
Boy, that sure seems to crank fast, like low compression. Perhaps cam timing, negative valve lash? Do a compression test.
   / WOAH! Won't Start! What have I done? #6
) Is there spark at the spark plugs? You did not say where you tested the spark.
2) What are the compession numbers?
3) When using starter fluid turn the engine over and squirt starter fluid in(while turning) to stop the big back fire.
NEW HOLLAND 706 30 INCH 3PT DIRT SCOOP (A55301)
NEW HOLLAND 706 30...
2018 FORREST RIVER CRUISE LITE CAMPER (A52472)
2018 FORREST RIVER...
PREDATOR TRI-FUEL 13000 GAS PORTABLE GENERATOR (A54757)
PREDATOR TRI-FUEL...
2021 CHEVROLET SUBURBAN (A53843)
2021 CHEVROLET...
2018 MACK CHU613 DAYCAB (A53843)
2018 MACK CHU613...
