WJSchrock
   / WJSchrock #2
   / WJSchrock #4
I have no idea what a magnetic alternator is. You can test a normal alternator a volt meter. When the tractor is running at about mid throttle the volts should read about 13.8 - 14.2. Right after starting it can read up to 15 or so volts for a short time. If you don't have a volt meter then hold a metal screwdriver or similar to the rear bearing on the alternator. If the bearing is magnetized then the alternator is charging. More magnetizm equals higher volts.
UNUSED Folding 4-Step Stool Ladder (A53117)
UNUSED Folding...
2019 MACK PINNACLE P164T DAY CAB ROAD TRACTOR (A51406)
2019 MACK PINNACLE...
New Kivel Skidloader Double Bale Spear (A50775)
New Kivel...
New Hay Saver Round Bale Feeder (A50775)
New Hay Saver...
JOHN DEERE 3032E TRACTOR (A54756)
JOHN DEERE 3032E...
2014 CATERPILLAR 308E2 CR EXCAVATOR (A52705)
2014 CATERPILLAR...
