Wiygul1
   / Wiygul1 #1
Wiygul one
1954 Ford naa
Brand new to forum but really need some help figuring out a tractor problem.
I own a Ford naa and it is a great tractor but I can稚 keep the lift arms down when I speed the tractor up, unless I have quite a bit of weight on it ?
Also own a Ford 600 working on.
   / Wiygul1 #2
:welcome:
To the TBN forum. This is a great site with a lot of knowledgeable people on it. :thumbsup:
   / Wiygul1 #4
:welcome: to TBN...enjoy.
   / Wiygul1 #5
:welcome:
Welcome to the forum!
I'm going to move this thread over to our Ford section. There are a lot of knowledgeable people over there :)
   / Wiygul1 #6
Do you still have the OEM pump on your NAA, or have you or someone else put a pump on it from a 600 + series. Your exhaust valve is rated for a max of 2.9gpm, the later pumps can make 4gpm... that will make the lit arms tend to rise unless weighted. If you have the older square vane pump and the hyd flow control, try turning it down a bit.
Also, if your oil is dirty and watery, it will not pass thru the exhaust valve as easy.
If you have heavy gear oil in the hyds that can cause issues too. I like to use UTF fluid instead.
2018 INTERNATIONAL LT625 (A53843)
2018 INTERNATIONAL...
2016 Hurricane Blo-Vac X3 Stand-On Blower (A50324)
2016 Hurricane...
Air Exchange rotary screw air compressors (A53117)
Air Exchange...
Ford Super Duty Pickup Truck Bed (A51691)
Ford Super Duty...
Target Ecoline Walk-Behind Concrete Saw (A49461)
Target Ecoline...
