Wix filter instead of JD filter
   / Wix filter instead of JD filter #1
dkostiha
Bronze Member
Austin, Texas
John Deere 3120
I am about to chnage my hydraulic/trans fluid and filter. JD wants $84 just for the filter by itself. O'rielly Auto Parts has the Wix brand filter for it for $10.84
It was only 10-20% higher for the JD OEM filter, I would not think twice, but to be 800% higher makes me think twice. Has anyone else been using Wix filter for trans ? Any issues or concerns with Wix filters ?
   / Wix filter instead of JD filter #2
Go for that cheap one and let us know how it works out for you. ;)
   / Wix filter instead of JD filter #3
Im running a Wix on my 4400 hydro. No issues for two years. Check the Wix specs for you filter and confirm the micron size meets your requirement.
   / Wix filter instead of JD filter #4
What tractor are you working on? I would also be curious to if the filter specs are the same. $84 seems high for a hyd filter $10 seems a tad too cheap for a hyd filter. Maybe not for a lube filter though.
   / Wix filter instead of JD filter #5
I know I paid about $40 for the last hydraulic filter for my 2320.. BUT someone found out that JD now listed a much cheaper filter for the same job..
In my experience the JD filters have similarly priced with other mfg filters (and somethimes even cheaper).. So something tells me that that $84 filter has something more going on for it than the $11 filter..
Also how did you get a cross ref number for that filter? I tried to find a cross for mine.. the OEM was a donaldson and that JD number would not even cross reference on the donaldson website
Brian
Brian
   / Wix filter instead of JD filter #6
Wix makes filters for alot of MFRs , and is equal speced to others..They made some NAPA...I have used their diesel fuel filters for years. My autos only get orig. filters.
1995 GMC CHIPPER/BUCKET TRUCK (A54607)
1995 GMC...
2022 Toro Workman 07921 Electric Utility Cart (A54811)
2022 Toro Workman...
2012 VOLVO A40F 6X6 OFF ROAD DUMP TRUCK (A52705)
2012 VOLVO A40F...
2013 Ford F-150 4x4 Crew Cab Pickup Truck (A53422)
2013 Ford F-150...
2016 FREIGHTLINER CASCADIA (A53843)
2016 FREIGHTLINER...
