Wisconsin THD on JD 24t hay baler
   / Wisconsin THD on JD 24t hay baler #1
bbk
Kennebunk, Maine
JD955
I am baling hay with a JD 24t with a THD and looking for someone who has or is familiar with same. Question: on the GOVERNOR LEVER, which hole (1-12, with 1 on the bottom) is the governor spring attached to? Is your spring 20 coils or 24 coils? Does your governor lever have a hook at the top or is it just flat? I have called Wisconsin factory and John Deere - neither could answer the question - too old a set up for them. Machine runs OK but as I bought it used, I'd like to know if it is set up properly.
bbk
   / Wisconsin THD on JD 24t hay baler #2
:welcome: to the forum.
Are there several sizes of THD ?
Might be you need to be more specific to what you have?
   / Wisconsin THD on JD 24t hay baler #3
My JD 24T Manual does not describe much in the way of setting up the Wisconsin engine power module. However, it does reference an "Engine Operator's Manual". I would be on the lookout (eBay or ???) to find this JD published manual.
By the way, I checked out all the pictures of the Wisconsin engine mounted on the 24T baler in my manual and none of the pictures show the gov linkage to see which holes are used - sorry.
thanks for both replies. the spec number on my engine is 137997. serial is 3995530.
the engine manual referred to in the baler manual turns out to be the Wisconsin THD factory operator's manual that was originally supplied with the baler. Both came with the baler but neither shows this adjustment - go figure
I think what I need to find is someone who has or had one of these
thanks again
2007 CHEVROLET SILVERADO TRUCK (A54756)
2007 CHEVROLET...
2008 Dodge Avenger Sedan (A53424)
2008 Dodge Avenger...
2016 FORD F250 XL SUPER DUTY EXTENDED CAB TRUCK (A51247)
2016 FORD F250 XL...
2015 SkyJack SJ86T 4x4 86ft Telescopic Boom Lift (A52377)
2015 SkyJack SJ86T...
1988 Kenworth W900B Dump Truck with 3406B CAT (A55218)
1988 Kenworth...
2004 MACK GRANITE CV713 DUMP TRUCK (A51406)
2004 MACK GRANITE...
