Wiring on BigTex Dump Trailer?
   / Wiring on BigTex Dump Trailer? #1
NIdaho
Bronze Member
North Idaho
Coming into the Battery/Pump box on the tongue are 3 wires.
  • White
  • Red/Orange
  • Blue
Am I correct to assume that the
WHITE is Ground and should be attached to the negative terminal of the trailer battery
BLUE is the power to the Break-away Switch and should be connected to the "+" terminal of the trailer battery
RED/ORANGE This line is RED and then has a section of Heat Shrink with some sort of cylinder under the Heat shrink and then is ORANGE with an in-line 30 Amp fuse. I think this might be the +12 V (battery charge line) coming from the plug
Should the RED/ORANGE be connected to battery's "+" terminal as well or should there be some sort of Battery Charger/Isolator?
Thanks,
Bob
2015 Ford Escape SUV (A50324)
2015 Ford Escape...
UNUSEDX-STAR 72" QUICK ATTACH GRAVEL LEVELER (A51247)
UNUSEDX-STAR 72"...
1999 Ford F-550 12FT. Flatbed Truck (A51692)
1999 Ford F-550...
Kubota BV4160 (A50123)
UNUSED RAYTREE RMPP680 HYD POST POUNDER (A51248)
UNUSED RAYTREE...
JOHN DEERE F725 LOT NUMBER 91 (A53084)
JOHN DEERE F725...
