wiring light bar
   / wiring light bar #1
1TMatthews
Bronze Member
Dunstable,MA
Kubtoa B3200
Hello I just bought a LED light bar for my B7800 does anyone have any wiring diagram to wire something like that in.
TMatthews
   / wiring light bar #2
Need more information, such as current draw etc. LED's usually don't draw much current (amps), but that also depends on the quantity of LED's that are in the light bar. Possible for you to post a picture? I assume that this came with some instructions? /forums/images/graemlins/confused.gif
   / wiring light bar #3
WOW! LED light bar for a tractor, what for?
Blake
WA
   / wiring light bar
just some extra warning power
   / wiring light bar #6
You might get more responses to something like this if you post it in the CUSTOMIZATION thread of the main forum instead of the Kubota area.
However, that said, you should be able to tap the alternator stub on the left side of your engine for the power, then run the wire into a switch that you install on the plastic cowling under the steering wheel. I did that to power a 12volt outlet on a B2910 last year, the install was very clean and it did not require tapping into to the fuse box, which can sometimes be a pain to access.
Check your current draw to make sure your alternator is large enough to handle the extra load, you may find that you are forced to turn some other lights off in order to run the light bar if the alternator is not up to the task. Or, if you are only running the light bar for fairly short durations, then you will probably not notice much problems, the battery may drain down a little bit each time you use it, but as long as the drain down doesn't get too far, the alternator will bring the battery back up. It may shorten the life of the battery under some conditions.
   / wiring light bar
to see some pics of light bar got to Lawnsite.com and go under tractors
2018 DRAGON PRODUCTS 130BBL VACUUM TRAILER (A53843)
2018 DRAGON...
2012 DIAMOND CARGO FOOD TRAILER (A53843)
2012 DIAMOND CARGO...
Generac Yanmar 5000Watt Heavy Duty Diesel Generator (A54811)
Generac Yanmar...
Plasmarc PM150 Plasma Cutter (A51691)
Plasmarc PM150...
2018 Suzuki KingQuad 750 AXi 4x4 ATV (A51691)
2018 Suzuki...
2017 CATERPILLAR D6T LGP HI TRACK CRAWLER DOZER (A52705)
2017 CATERPILLAR...
