Wiring for the Injection Control Pressure Sensor on a PowerStroke.
   / Wiring for the Injection Control Pressure Sensor on a PowerStroke. #1
jigs_n_fixtures
Veteran Member
Salmon, Idaho
TYM T233 & T293 CAB
I want to mount an electronic hydraulic pressure gauge on my tractor. I found a gauge with a 4,000-psi max reading, which ties into the wiring for the ICP sensor on PowerStrokes.
Does anyone know which of the three wires in the wiring harness is what? I’m guessing one is 12-V power, one is ground and the other is teh sensor. But not owning a PowerStroke I don’t have any way to figure it out.
Thanks, Randy
   / Wiring for the Injection Control Pressure Sensor on a PowerStroke. #2
Hot
Ground
5v reference from CPU.
I don't know how you are going to get a good reading without a 5v reference from a CPU?
I can get a 12V to 5V power supply fairly easily. Gonna have to keep looking at this a bit longer.
MAXUM M-1000 TRIPLEX PUMP POWERED BY 3412 CATERPILLAR ENGINE (A50854)
MAXUM M-1000...
2025 10ft X 20ft Single Garage Metal Shed (A48081)
2025 10ft X 20ft...
2008 Honda Civic EX Sedan (A48082)
2008 Honda Civic...
2019 Ford F-450 4x4 Crew Cab and Chassis Truck (A49461)
2019 Ford F-450...
2015 Volkswagen Passat Sedan (A48082)
2015 Volkswagen...
RIMS AND TIRES (A50854)
RIMS AND TIRES...
