Wiring Diagram for Yanmar 2201D
   / Wiring Diagram for Yanmar 2201D #1
QBH
Bronze Member
Alachua, FL
Yanmar 2210D, Kubota BX25D, Gravley PM260Z ZTR
Can anyone tell me where I can get a wiring diagram for a 2210D? I bought an operators manual from Hoye Tractor, which has wiring diagram in it, but it is not right for my tractor. Specifically it shows a dynamo and regulator, where mine has an alternator. At this time, I really just need the alternator wiring, but I would like to have an accurate drawing.
Larry
   / Wiring Diagram for Yanmar 2201D #2
Larry have you found your answer about this wiring diagram? I know this thread is almost 5 months old, but I didn't see it before.
No, still haven't found one.
   / Wiring Diagram for Yanmar 2201D #4
Larry I have a 2210d. I could write mine out for you if you would like. It will take me a few days, because it's a busy time for me right now. But if you need it I could do that. Let me know Jon
Thanks Jon. I don't have the tractor in front of me right now, but basically I am trying to find out the interconnects between the alternator, and the ignition. As I recall there are three wire on the alt, a ground and two others. I don't remember how many are on the ignition switch. Any information you can provide would be greatly appreciated. I just cant seem to get my head wrapped around it, and I am not seeing the voltages that I would expect.
Whenever you get around to it, obviously it is not an emergency.
Again, Thanks.
Larry
   / Wiring Diagram for Yanmar 2201D #6
I understand. Sometimes it can be mind boggling. I will see what I can do.
2008 Mazda CX9 SUV (A50324)
2008 Mazda CX9 SUV...
2012 CATERPILLAR 304E CR EXCAVATOR (A51242)
2012 CATERPILLAR...
(9) 2 PLUG VALVES 1502 IRON (A52472)
(9) 2 PLUG VALVES...
Split Weight & Wheel Weight (A50515)
Split Weight &...
Bobcat B950 Skidloader Breaker (A50774)
Bobcat B950...
4' x 6' Tilt Trailer (A50515)
4' x 6' Tilt...
