aaristotle
Does anyone have a wiring diagram, especially showing wire colours for a Kioti EX50 CH?
I installed a voltmeter in the lighter socket after thinking the headlights and cab spotlights didn't seem very bright at times. I discovered that the voltage ranges from 13.2v when the tractor is running but nothing electrical is switched on to under 11v with lights, wipers and AC / fan on. The voltage at the battery terminals sits around 13.8v whatever the load.
I'm assuming there is a bad connector(s) or relay in the circuit however after I follow the cable from the battery to the starter motor the cable disappears into a loom and I am unsure of the path it takes to the various electrically powered equipment via connectors, relays, ignition switch, fuse box etc. Rather than diving in blind I would like to follow the circuits from the battery onwards. Also if there are any common points of failure to focus on that would help.
Aaron
Aaron
