Wiring diagram for BX2230
   / Wiring diagram for BX2230 #1
RaydaKub
Veteran Member
Rochester, MN
Kubota BX2230
Here I am again, another new thread. Anybody know the color coding and wiring scheme for a BX2230?
I have only the small turn lights on the back end and one red tail light. Everything else is dead. The larger round lights have both elements wired together and that part looks like it was that way from the factory. The bulbs appear ok, but I can't get anything out of them trying to hotwire them either. I get nothing for a volt reading in the sockets anywhere. I lifted the seat and found two different hot wires (on the key) and another ground wire. I'm thinking of adding some more lights and these two wires would seem to fit the bill, but without knowing what they were intended for, I'm a little gunshy of just hooking something up. Also, does the fuel gauge wire come up through this bundle as well? There's one pair that disappears up under the fender on the left side. A color code to go by would be extremely helpful as well as a diagram. Thanks!
I have a parts manual and it is quite extensive (pdf on cd). But it just says it is a wiring harness, not what the coding for the wires is. Helpful for the bigger stuff, but not for this.
   / Wiring diagram for BX2230 #4
On their Kubota page you list your tractor model. It gives you a list of tractor sections, electrical being one of these. They will then email a schematic of the electrical system.
If that doesn't work I expect you will have to buy a service manual. This they can also supply.
Got it. I'll have a look when it comes in. Thanks, didn't know about that service.
Well, it is somewhat helpful, but doesn't have the color coding I was hoping for. The bundle of wires coming to the rear end has some extra leads in it and nowhere to hook them up. It seems like I could use them, but... Still, those links were helpful to understand a couple things. Thanks.
2015 Peterbilt 320 T/A EZ-Pack Front Loader Garbage Truck (A51692)
2015 Peterbilt 320...
2018 CATERPILLAR 279D SKID STEER (A51246)
2018 CATERPILLAR...
2019 New Holland Workmaster 95 MFWD Compact Utility Tractor with 632TL Loader - Poultry Special (A52748)
2019 New Holland...
2006 TerraGator 8104 (A52748)
2006 TerraGator...
New Skid Steer Attachment Plate (A53002)
New Skid Steer...
2002 FREIGHTLINER FL80 FUEL TRANSPORTATION TRUCK (A52472)
2002 FREIGHTLINER...
