Wires by roll bar on 2400h
   / Wires by roll bar on 2400h #1
kgrover
Fayetteville
Branson 2400h
Does anyone know what the two sets of wires right by the roll bar near the fenders on a Branson 2400h are for? I'm guessing they are for work lights, but I have not been able to find a wiring diagram on this tractor to see where they actually go.
Also, has anyone been able to adjust the hitch to go up higher? I end up hitting my disk and plow on the ground if I go over a hill or berm. I just need a little more clearance. The piston is at the top of the stroke, I can hear the pump if I pull the control lever all the way up and it stops if I lower the lever just a bit, so I'm pretty sure I'm topping out the piston. Can I take the arms off and move them up a notch or two and then adjust the limit control?
Thanks.
   / Wires by roll bar on 2400h #2
The wires are hot whenever any of the running lights (headlights or aux switch) are activated. I use them for a rear work light that I added.
I moved the vertical link attachments on the arms to the rear position and got another inch or so of height.
JOHN DEERE XUV835M (A53084)
JOHN DEERE XUV835M...
2025 CFG Industrial MX15RX (A50123)
2025 CFG...
2017 TROXEL 130 BBL STEEL VACUUM TRAILER (A53843)
2017 TROXEL 130...
2015 Ford Taurus Sedan (A51694)
2015 Ford Taurus...
2015 Ford F-250 Knapheide Service Truck (A51692)
2015 Ford F-250...
International Cab and Chassis (A51692)
International Cab...
