California
Super Star Member
- Joined
- Jan 22, 2004
- Messages
- 16,596
- Location
- An hour north of San Francisco
- Tractor
- Yanmar YM240 Yanmar YM186D
I see another thread about routers with some excellent replies. Hopefully someone has advice for what I want to do.
Recently my DSL service was upgraded to FTTN, ATT's Uverse. Unlike the Netgear routers I've used for years, I have to use ATT's all-in-one modem/router as my central router so its time to replace several old pre-WPS remote devices - print server etc - that have security software so primitive (or none) that this new Arris router won't issue them an IP.
What I have in mind is repurpose a Netgear router (actually, I have three) as a server to my Ethernet-interface Laserjet in another room, then other Netgear routers driving Ethernet-to-USB boxes for USB printers elsewhere. Presently this all works by Ethernet-over-powerline to the remote Laserjet and the USB converters but only one of the several destinations broadcasts Wifi at the destination end. Now if I put Wifi routers at those remote locations then much stronger Wifi signal will be available there.
(Simplified a little, I need similar setups at home in town and another out at the ranch. To minimize cost I want to re-purpose existing hardware).
Ideally I think the highest speeds would be attained by setting up each of these remote routers to receive signal into its ethernet port and rebroadcast that signal locally as wifi. I already have one device that does this, TP-LINK TL-WPA4220KIT Wi-Fi Powerline extender kit with 2 LAN ports. (Amazon link). The remote end has two Ethernet ports and a Wifi transmitter; everything works like magic using new-to-me WPS. Just press a button at each device and they create a secure link, no more logging into 192.168.xxxx to make stuff work. Instead of buying a $45 WPA4220 receiver for each destination I would like to re-purpose my old routers to do the same function.
What I'm curious about is can these existing routers be told to become a downstream repeater to the central Arris router. Turning off their DHCP is obvious but how do I get them to request a link from the Arris, and to receive their signal into the Ethernet port instead of over the air? Receiving via Wifi requires setting everything to a fixed permanent wifi channel per Netgears manuals. I don't want that. In town all channels have activity and I want to preserve the ability for that router to jump channels as needed.
Each of my Netgear routers has a configuration page to make it the host of cascaded routers but Netgear says Not Recommended to use these in a cascaded network. Anybody know why that is their advice?
Hardware available: N300 and N600 Netgear routers WNR2000v2, same v3, WNDR3400v2. Netgear W300RE Wifi repeater. All with WPS. Two 5-port 100 Mbps switches, not in use. (All the preceding are $5 thrift store finds, all work fine
). Two $30 TP-Link AV500 Ethernet over powerline kits. (Ethernet, not Wifi, at the destination end). The $50 WPA4220 Ethernet over powerline kit described above, is the only Powerline set with a Wifi transmitter at the destination. Some wired Ethernet devices at the destinations. And there are several Wifi clients at each destination when the whole family shows up. I want to give the kids good signal way down at the back of the guest cabin.
Somebody must have done this. How do I configure these destination routers to request an IP from the central router, over Powerline, then rebroadcast wifi and Ethernet? is WPS bi-directional in this case or are these routers only capable of hosting?
Baffled ...
Baffled ...
