wireless cameras
   / wireless cameras #1
heehaw
Veteran Member
russellville, arkansas
Kubota M4900, B7510 and RTV
has anyone used a x10 wireless camera? i would like to know how far anyone has them spaced and they still work?
heehaw
   / wireless cameras #2
I have not used an X10, but I have a D-link at home that works very well with my wireless router. It's about 50 ft from the router in my house. The only suggestion I have is to buy a camera that's "internet ready", they talk directly with a wireless router and you can access them from anywhere via the web...........
   / wireless cameras #3
I have an x10 and I've had no problem with video directly to the TV, but have had no sucess hooking it up to the VCR.
   / wireless cameras #4
Same here, sorta. Picture on TV looks good. Signal goes thru the VCR to the TV. I can hear the motion detector sensor click but the VCR will not start. I followed the instructions but I can't figure it out how to get it programmed to start the VCR.
   / wireless cameras #6
Yes, I have a few of them. They work O.K. But remember, if someone walks between the sending and receiving units, the signal fuzzes out. The farther apart they are, the easier it is to kill the signal. I also have a few wired units. They work fine for the price. They are susceptable to sunlight damage if the lens is pointed directly east or west where bright sunlight can burn out the chip, so put them under an eaves or something when planning the installation. I have mine about 50' max between the senders and reciever.
As for their VCR commander, it really does work, if you can figure out how to program it. Google search for x10 VCR commander setup for help. I set up a couple of eagle eye motion sensors and set up the VCR commander, and a couple cameras. I threw a 4 hour tape into the VCR figuring that would be enough, since it was supposed to record for 5 minutes after motion ceases.
When I came home, the tape was ejected... all used up. I reviewed it to see what happened. A robin flew up on my gate, trigger the motion sensor, pooped on my sidewalk and flew away. Then 5 minutes of nothing. Then the robin came back from the other direction, landed on my gate, pooped and flew away... you get the idea. 48 clips of a robin pooping on my gate.:p
Enough of that. I stopped using the VCR commander and the eagle eye motion sensors. Instead, I hooked up the cameras to a PC with video capture card and a motion sensing video capture program. It works much better and records to the hard drive. It senses motion by comparing the picture from time to time and is easily adjusted to account for something like a bird or rabbit but still pick up large dogs and people. You can set it to FTP video clips or stills to a website or e-mail when there is an event. Lots of options.
   / wireless cameras #8
The issue with almost all wireless cameras is distance and obstruction. They work at much longer distances when there is only one wall between the router and the cam than they do with several walls. There is little difference between the higher priced models range and the bargain models. Price gets you better resolution and optics, but range is about the same.
Both of my cams are IP or Internet cams, but only the Toshiba is wireless. The signal has to pass from my computer room in the back of the house to the front porch, through 2 interior walls and one exterior log wall, about 75'.
Lots of my weather station buddies have wireless cams and the info I've listed echo their experience. I don't necessarily think that you need to use IP or network cams. The less expensive cams work fine when combined with a nice multi-port capture card, and, as mentioned, there are many software choices for motion detection and capture.
Hope this helps!
   / wireless cameras #9
I've had x10 camera's for years, kind of a kludge getting it to record on a vcr.
also, you only can view 1 camera at a time, so kind of defeats the purpose of having multiple cameras.
I now have a DVR video card with 4 camera hookup, I currently have 2 wired cameras connected, and my X10 reciever is also hooked up. The software with the card is great, you can set up to only record based on motion, records to the hard drive, can access remotely via internet (with dyndns, or static ip).
The wired cameras are better. The screen image jumps a lot with the wireless cameras, so it is sensed as motion and everything records.
I bought another brand wireless camera recently, my x10 reciever picks it up, so I can't run both the new one and the x10 together, the stongest signal is picked up by both recievers, they use the same freq.
   / wireless cameras #10
BB_TX said:
Stephen - Thanks for that link. I will give it a try.
David - Where did you get that software for your PC?
It is called Active Web Cam.
Here's a link to their website.
They have several levels of features for different prices. I am running an older version on a windows 98 PC that included lots of features for the $29.00 price. Now it is more $$ for the same features for WinXP.:mad:
One thing to note. The more cameras you add, the less quality you can record movies at, because your processor has more data to deal with. I find pictures to be just as effective as video and take up way less processor time.
UNUSED LANDHONOR UNIVERSAL ADAPTER PLATES (A54757)
UNUSED LANDHONOR...
48" WIDE WOODEN W/ METAL RAILING (A54757)
48" WIDE WOODEN W/...
2009 Trail King TK110HDG-523 RGN 66 Ton Tri-Axle Lowboy Trailer (A52377)
2009 Trail King...
1977 Ford F-100 Ext. Cab Pickup Truck (A53422)
1977 Ford F-100...
2022 MACK GRANITE TANDEM AXLE DUMP TRUCK (A54607)
2022 MACK GRANITE...
2017 Hino 268 20ft Flatbed Dump Truck (A52377)
2017 Hino 268 20ft...
