Wire harness/switch for emergency beacon
   / Wire harness/switch for emergency beacon #1
lowechj
Huntsville, ON Canada
Kioti CK3510SE
I am the new owner of a CK3510SE which replaced my 06 JD 2510. I got it half way through the February so not a lot of hours so far. I noticed that up where the smv is there is a wire and connector that must be pre wired for a some kind of emergency beacon. If the wire harness is there I would imagine there must be a provision for a switch. There are 2 blanks next to the switches for the wipers, work lights etc and several blank spots below the steering wheel next to the cruise control switch.
Would anyone know where the switch might go to turn on a beacon if I want to install one. I also found a " hot wire " at the rear hidden below the windshield washer container, if I can find the right connector I hope to add an extra led work light.
Any help would be appreciated.
   / Wire harness/switch for emergency beacon #2
My JD4100 had a connector in a similar position. It powers up when the headlights come on. I hooked my LED rear flood to it.
1998 Dodge (A50121)
1998 Dodge (A50121)
2017 Buick Encore SUV (A50324)
2017 Buick Encore...
1993 Ford Ranger STX Ext. Cab Pickup Truck (A50323)
1993 Ford Ranger...
2013 GMC Terrain SLE SUV (A50324)
2013 GMC Terrain...
2005 CATERPILLAR 321C LCR EXCAVATOR (A51246)
2005 CATERPILLAR...
Caterpillar CB-54 XW (A50120)
Caterpillar CB-54...
