Winterizing 3pt sprayer
   / Winterizing 3pt sprayer #1
JSM
Texas
New Holland
All,
What is the best way to keep a sprayer from freeze damage? Remove screen, drain, and blow lines out with compressed air? Or, pump antifreeze through it?
Thanks in advance for the help.
Joseph
   / Winterizing 3pt sprayer #2
I have never had to worry about winterizing the pump on my ten year old sprayer. The nozzles though will freeze and bust. I blow air through the nozzles.
   / Winterizing 3pt sprayer #3
The Fimco brand sprayers recommend running "RV grade" antifreeze through the sprayer. Not sure how that is different from the regular stuff.
I would say try and pump it dry then do the antifreeze and you should be good.
   / Winterizing 3pt sprayer #4
I run compressed air through mine to winterize it. I use regular anti-freeze in the pump, and put a little (~1 quart) in the bottom of the tank too.
   / Winterizing 3pt sprayer #5
I run the RV antifreeze through all 4 of my sprayers. Empty all screens and pumps of water first, then circulate the RV antifreeze through system, then last out the nozzles. The RV grade is non-toxic, won't poison pets or soil, so safer to use. Been doing this for 15 years, yet to have it fail. Wouldn't trust air pressure to get water out of everything.
   / Winterizing 3pt sprayer #6
Good point about the RV stuff being nontoxic. Another good thing to consider is using nutra-sol or similar product which neutralizes spray chemicals, to avoid cross contamination.
   / Winterizing 3pt sprayer #7
I've always used ammonia to wash the tanks when done spraying for the year. Use on my 750 gal field sprayer all the way down to the 25 gal ATV sprayer. Cleans out the residue.
I use my yard sprayer to spray roundup on the driveways, rinse with water, wash out with ammonia/water, rinse, then use it for tri-mec on the lawn in fall.
   / Winterizing 3pt sprayer #8
I have a Fimco 15 gallon pull-behind sprayer. I winterize it by pouring a couple of cups of pink RV antifreeze into the tank (along with some water or whatever else happens to be left in there) and then run it for 30 seconds or so. If you do it this way, DO NOT forget to also run some of this mixture through the wand, or it will freeze and crack the plastic valve.
   / Winterizing 3pt sprayer #9
How much ammonia do you use?
   / Winterizing 3pt sprayer #10
For the small sprayers, I use about 2 cups of ammonia to 3 or 4 gals of water. Use the wand to spray the walls of the tank down, agitate, spray solution out booms/nozzles, rinse out. On the 750 gal, I use about 1/2 gal ammonia to 30/40 gals water.
2016 Peterbilt 320 T/A EZ-Pack Front Loader Garbage Truck (A54814)
2016 Peterbilt 320...
2004 TRAILKING 101" X 53' STEP DECK TRAILER (A50459)
2004 TRAILKING...
2024 JOHN DEERE 6155M LOT NUMBER 9 (A53084)
2024 JOHN DEERE...
2013 Ford F150 Pickup Truck (A53422)
2013 Ford F150...
2014 FREIGHTLINER CASCADIA SLEEPER (A54313)
2014 FREIGHTLINER...
