winterize a dishwasher
   / winterize a dishwasher #1
goaliedad
NORTHWEST MICHIGAN
KUBOTA L175
I have been asked to help winterize a house- power is off, it is on a private well. I have drained the water heater and pressure tank, opened all faucets and hit the toilets and all traps with RV antifreeze. If power were available I would run air thru the lines- I hope gravity is enough.
The one thing that I'm not sure of is the dishwasher- should I pull the supply line and drain line, and pour antifreeze thru the bottom of the unit?
   / winterize a dishwasher #2
Yes and it the house has a washing machine you need to winterize it the same way.
   / winterize a dishwasher #3
If the referigerator has a icemaker you need to drain that line also.
The washing maching will have to be disconnected and you will have to get RV antifreeze into the washer pump.
2004 MACK GRANITE CV713 DUMP TRUCK (A51406)
2004 MACK GRANITE...
2018 KENWORTH T800 DAYCAB (A53843)
2018 KENWORTH T800...
Brent 420 Grain Cart (A55301)
Brent 420 Grain...
2018 John Deere 30G Mini Excavator (A52377)
2018 John Deere...
Scag Mower (A50324)
Scag Mower (A50324)
2015 JOHN DEERE 250G LC EXCAVATOR (A52705)
2015 JOHN DEERE...
