devongarver
Ok, so I am having a bit of a conundrum here. I will be using my tractor for snow removal this year. I am currently keeping it outside, because I am using it for VERY muddy chores every few days ever since I purchased it. (I practically live in a swamp, and I have been digging ditches to correct that). I have my mustang stored in the garage, and it will of course remain there all winter(I live in Northeast Ohio). I have room to park the tractor in the garage, but I am worried about the snow when it melts off the tractor after using it this winter. have no floor drains in the garage. Instead, the floor is pitched about 1/8" per foot to drain the water to the front towards the door. The problem with this, is it will hit my door seal and pool to the sides, which will then hit the wooden base of my work bench which is simply not acceptable...
The garage is not heated, however it is attached to the house and remains around 40 degrees most of the winter. At the plumbing company I used to work for, we stored a Kioti 4wd tractor, a CAT skidsteer, and an IHI trackhoe outside in one of those metal framed tarp covered car port things you can buy for 300$ or so. All of this equipment was used in the winter, and none of it was hooked up to engine block heaters. We simply let the glow plugs warm for 30secs or so and they all would fire right up. But....of course I am a scaredy-cat, as this tractor is my baby, and I am worried about leaving it outside all year in one of these carport things.
So-the real question here-is there any harm in leaving the equipment outside during below freezing temperatures? I got below zero last year quite a bit as well. I am worried about the hydraulic lines, the oil, and honestly just the severe heat cycling that everything will experience going from ice cold to full operating temps...
This brings another question, would a block heater be beneficial? And if so, where can I get one/which type/brand should I get?
Pretend I know nothing at all, and school me on winter usage here. I promise I will not be offended!
:confused2:
:confused2:
