Winter protection for hydraulic rods?
   / Winter protection for hydraulic rods? #1
jaybrad
Central Maine
Massey Ferguson GC 2310TLB
On another thread there has been discussion about putting grease or oil on hydraulic rods that will be outside over the winter. Which got me wondering about what folks do who store BHs in a garage out of the elements?
My BH is on a dolly in a storage room in my garage. The garage is dry and insulated, but not heated.
Looking for suggestions.
Thanks,
Jay
   / Winter protection for hydraulic rods? #2
Inside you probably have nothing to worry about. That being said you wouldnt hurt anything by wiping the rods with a little grease. Just remember to wipe it off with a little paint thinner in the spring before use
   / Winter protection for hydraulic rods? #3
You probably have one of the worst places to store equipment there is. It would be better off outside in the elements. Here is why. When you have any equipment indoors and not heated, the temp changes will create condensation. You have it in a garage and weathered in which means no air movement. Therefore, the condensation has nowhere to go. Classic car enthusiasts figured this out a long time ago. An old car in an unheated garage rots as fast as anywhere. In your situation, if there is no heat, you need air exchanged with outdoor air to get rid of condensation, insulation or not. Don't believe me? Check your equipment on a sunny, cold afternoon.
   / Winter protection for hydraulic rods? #4
I am not sure why you would need to wipe it off with paint thinner in the spring before using, as a couple rags or shop paper towels would probably do the trick and not risk the paint thinner reacting with the seals of the cylinders. The paint thinner might not hurt the wipers or seals, but why chance it? Leaving a little bit of the grease on probably would hurt less than the paint thinner, as long as it isn't full of dust.
David from jax
   / Winter protection for hydraulic rods? #5
A little paint thinner on the rag to break down the grease after storage helps. Thats always how i was shown to do it when i was an apprentice. Dirt and other crap can get embedded in the grease during storage and possibly damage the seals in use. Thinner (ie mineral spirits) wont hurt the seals and get the job done a little quicker.
YMMV:D
   / Winter protection for hydraulic rods? #6
Inside - do nothing. Just wiggle the controls after the engine is off to remove pressure..
Outside, maybe spray with silicone or slather on grease or do nothing. The chrome is a rust barrier.
jb
I should have explained that the garage is attached to the house. My wife's car (and my tractor) are in the garage, which means twice a day, the garage door is fully opened as she goes to/from work. I don't remember it every getting below freezing, but it does become a nice walk-in refrigerator for a couple months. The temperature really doesn't swing all that much, even on a sunny, cold afternoon.
My motorcycles have survived in this setting without rotting away. :eek:
It sounds like a lubricant/spray and tarp are a good idea, then a Spring wipe down.
Thanks all,
Jay
   / Winter protection for hydraulic rods? #8
Hey, Jay-- I'd second Wayne County's remarks-- Please check carefully for condensation. I have the same proble here, but have largely solved it by ensuring ventilation through the garage, adjusting as necessary. Slop from cars I vaccum up with a wetvac and dump outside.
My ol' 360 had developed a lot of "surface" rust pits on it- had to go over the whole thing with Nevr'Dull this fall. No, it ain't pristine by any stretch, but still, I was surprised to see how much had accumulated last winter & over the summer (don't drive it too much) from humidity in the garage....
  • CB360T (8:08).JPG
    CB360T (8:08).JPG
   / Winter protection for hydraulic rods? #9
I think treating the chrome on he cylinders is just more obssessing over our tractors. If the cylinders are of good quality the should not rust unless they have been chipped or scratched. My old Deere 8b bachoe set outside every day I owned it for 13 years. The cylinders showed absolutely no signs of rust. If you want to treat your cylinders........go ahead if it makes you feel better, but I don't think it's necessary. It sure won't hurt. If your cylinders do rust, I'd change brand on tractors on my next purchase.
Sincerely, dirt
   / Winter protection for hydraulic rods? #10
I second that dirt. Most large equipment never sees the inside of a building and the rods never rust.
1982 LeeBoy Motor Grader (A53472)
1982 LeeBoy Motor...
2025 New/Unused LandHonor Heavy Duty Plate Compactor (A51573)
2025 New/Unused...
2007 Hino 268 Truck, VIN # 5PVNE8JVX72S50442 (A51572)
2007 Hino 268...
DOWNING MANUFACTURING BITUMINOUS APPLICATOR (A51406)
DOWNING...
Komatsu WA250-5L Wheel Loader (A52384)
Komatsu WA250-5L...
Hotsy Pressure Washer (A51573)
Hotsy Pressure...
