Winter Prep
   / Winter Prep #1
Larry Caldwell
Super Member
Myrtle Creek, Oregon
Kubota l3130
It has been an unusually mild autumn here. We still haven't seen first frost, which normally happens in October, so I have had plenty of time to prep for bad weather. I was running tasks through my head and wondering if I had forgotten anything. So far;
Winter tires on vehicles and new wiper blades. First legal day for studded snows is November 1. Summer UV and heat kills wiper rubber. Test vehicle batteries. Winter kits in vehicles. You might think antifreeze, but that is one of my spring rituals. Service the cooling system before you need cooling. šŸ˜Ž
Sweep and inspect the chimney. Service and inspect smoke/fire alarms. Cutting firewood is a winter project, so the wood shed was already full by Sept. 15. Check weather-stripping on doors and windows. Clean gutters again and again until leaves quit falling.
Get Christmas lights ready to turn on after Thanksgiving next week.
Service and test generators. I have four of them, one for the house and each outbuilding. This year I am adding a lithium battery UPS for the modem/router so our cell phones and tablets will work without running a &$&% noisy generator. The house generator runs on propane and the tank is full. The other generators are gasoline, but only run occasionally. 10 gallons of gas is plenty. The propane generator is a Home Depot 8/6 kw special only 4 years old, but the hoses all rotted and fell apart. Extreme fire hazard. I was not pleased.
Inspect and repair water system insulation.
Plenty of staples, other ingredients, and supplies if we decide not to go to town for a couple of weeks. We're retired, and if we don't want to go anywhere, we don't. The wood stove has a good cook surface and I have a gorgeous antique hand crank coffee mill, so the essentials of gracious living are covered.
Batteries. Tractor Supply had 1300 lumen rechargeable LED flashlights in stock for under $15 that will save me big bucks on AAA and AA batteries. 2.5 hours on high.
Waterproofing all my outerwear, greasing my boots so they can dry before I need them, digging out winter hats, caps, and gloves.
Yard and garden cleanup. Get the sprayer off the tractor and mount the blade.
What other seasonal tasks are appropriate this time of year?
   / Winter Prep #2
I am doing my winter prep early also. I think I'm about halfway through the list.
It is a more enjoyable job when it is a calm 65° day.
It's not easy to set the driveway markers with an inch of frozen ground on top.
   / Winter Prep #3
For me cleaning gutters and downspouts after the leaves drop and furnace/filter tune up top my list as it doesn’t snow here.
   / Winter Prep #4
That is a serious prep list, but you might have missed a few water system details. Did you drain all the outside water faucets and store the garden hoses to keep them from freezing? Also, it is a good time to stabilize the fuel in your lawnmower and other small gas equipment before putting them away for the winter.
   / Winter Prep #5
Winterizing sprayers and pressure washer with RV antifreeze, blew out drip irrigation lines tomorrow, winterized RV, pontoon, down state and tritoon up north. closing and draining water line to unheated part of barn, walked around with a concoction of marvel mystery oil and seafoam putting it in 2 and four stroke lawn care equipment. Plugging in all tractors and electric start equipment to battery maintainers. Ran around with my cordless DeWalt grease gun greasing all fittings on equipment. Cut and split several face cords for wood stove up north and fireplace down heren this summer. Put qa backwoods hacked plow on tiny tractor up north put ATV plows on down here and tire chains and weight box, and plow on ATV up north. Waiting to get my 3/4 ton back from getting extensive upgrades to put my new to me boss plow on already put new tires on it this fall. Will weld pipes on cutting edges when I get it back. Currently working on getting three what my state considers vintage snowmobiles up and running. Test ran my small walk behind snow blowers up north and down here. Got My 4k hr Honda 6k generator running. I'm sure Im forgetting other things have done already.
2016 Club Car Carryall 1500 4x4 Utility Cart (A55758)
2016 Club Car...
Moffett M5000 Truck Mounted Forklift - 5000 lbs Capacity - Side Shift (A55315)
Moffett M5000...
2021 Ford F-150 4x4 Ext. Cab Pickup Truck (A54814)
2021 Ford F-150...
2009 Peterbilt 335 Cab and Chassis Truck (A55852)
2009 Peterbilt 335...
2015 Ford F-550 (A55973)
2015 Ford F-550...
2014 Kawasaki Mule 600 Utility Dump Cart (A55973)
2014 Kawasaki Mule...
