Winter Horse Set Up
   / Winter Horse Set Up #1
whistlepig
Elite Member
Preble County, Ohio
Kubota B7800 with FEL
We have our place set up pretty well for taking care of our horses during the winter. Always looking for a better way. Wonder what ideas and suggestions others may have to take care of livestock when it's cold outside.
   / Winter Horse Set Up #2
Horses seem to be comfortable in cold weather as long as they are dry and have a lot of water and minerals available along with grain or corn for heat/fuel. Having a 3 sided shelter that they are ALL comfortable in, is a must. If you want to keep you vet out of the barn, keep your horses out of there, too !
If you must put the horses in a barn though, make sure you don't have hay overhead. They give off so much moisture/sweat/humidity, that the layer of hay directly over their stalls will absorb it and may mold. If you clean the snow and ice from their corral area, the sun will warm the ground and they will like it better than laying down in the snow. To keep warm, they may get a bit frisky and that's when the fighting and kicking can start.
Again, if you feel you need to put them in at night, make sure they can all see each other. If they can't some will get anxious about their buddies and start kicking, chewing or pacing and dig some holes. Leave an aisleway light on too. so if you need to go out there after midnight, you won't be surprized by a visitor, a loose horse, or an unwanted guest.
   / Winter Horse Set Up #3
Keep water and grass hay in front of them all the time and a place to get out of the weather. Half the time when it is snowing or raining the horse and cow stand outside. If it is real cold like below 20 I give the horses some extra bag feed. The cows are on full feed any way. If they are big and fluffy they will be fine.
Dan
   / Winter Horse Set Up #4
Back in another time on the western prairies the Farm draught horses were simply turned out in a stubble field and/or pasture for the winter. Most times they had a straw stack available for extra feed. When there was no snow or open sloughs water had to be provided. Trees provided wind breaks and shelter.:D
   / Winter Horse Set Up #5
My wife and I have found heated water buckets and a heated water tub to make winter much less work. We have an electrically heated water bucket in each stall inside the barn that the horses can get to during the day. We also have a 50 gallon water tub with an electric drain plug heater in a paddock that the horses have access to. The water tub is inside an insulated wood box that has a 5 gallon bucket through a hole in the top. We do bring the horses into the barn for the night, as I sleep better knowing they are in their stalls.
   / Winter Horse Set Up #6
:D:D
Good point, Egon.
Mine know what winter pasture looks like. They have a good winter coat and a pond to drink from. Fed once a day and get to go to the stall when it gets down to single digit temps and windchills.
   / Winter Horse Set Up #7
You are focusing on a very important topic a lot of people that own horses do not think much about except when it is hot. Horses will almost always drink much less water when it is cold. When fed a lot of hay and grain to provide warmth, as I noticed in previous posts, water is essential to aid in digestion. It prevents compactions, which can be quite painful and deadly. Make sure your horse has access to a salt lick and is using it. We sprinkle mineral salt over their grain once a day too and noticed their water consumption is up when doing this. Unfortunately, we learned this lesson the hard way by losing a horse to a ruptured stomach caused by compaction/colic.
We keep the horses out year round unless the wind chill is well below zero. We also have a Nelson automatic waterer. We have a large run in shed for the horses. We bring the horses in twice a day for grain and then turn them back out. We hay them outdoors in hay tubs using an ATV. We have a good horse barn and could stall them if we wanted. The horses (and us) seem to be much happier when they are outdoors.
   / Winter Horse Set Up #9
I am horseless, however the local tax clerk keeps horses and in chatting with her, she told just me what you all have said. Her horses are very happy in winter with a simple run in shed and spend a lot of time out in the pasture by choice anyways.
I lurk on horse topics because I need to build a storage shed and have thought that making my property more horse-amenable will improve it's value, or appeal to more buyers when the time comes that I need to sell it. So why not build a storage shed that works well for horses? Does that make sense?
Dave.
2014 Volkswagen Jetta Sedan (A50324)
2014 Volkswagen...
2015 Infiniti QX60 SUV (A50324)
2015 Infiniti QX60...
2016 Ford F-550 Palfinger PSC3216 Crane Service Truck (A51692)
2016 Ford F-550...
Parker 400 bu Gravity Wagon (A50515)
Parker 400 bu...
John Deere 2020A Progator (RUNS) (A50774)
John Deere 2020A...
Polaris 90 Sportsman 4-Wheeler (A50121)
Polaris 90...
