Winter help for drought damaged lawn
   / Winter help for drought damaged lawn #1
lhfarm
Veteran Member
Central Indiana
NH TC40DA
We haven't had a good rain since July. My lawn is completely brown and I have a number of places that are bare from last winter's remodeling work. The grass planted last winter/spring is gone. This is a large lawn (at least a couple of acres) with 20+ walnut, oak and poplar trees (plus a few other species).
Should I over-seed the entire lawn now or wait for a snow? Do I need to scratch up the bare spots, seed and cover with straw now, or again wait for some moisture.
Any advice appreciated.
   / Winter help for drought damaged lawn #2
I'd cover with straw/hay then in the spring just before all the snow melts add seed?????
   / Winter help for drought damaged lawn #3
Given your location, I believe you are well past the planting dates for turf grasses (at least for those for which I am familiar). I think you are going to have to wait until next spring to reseed.
In case you don't get any replies from members in your area, check with your local Cooperative Extension office. Most states have a lawn/turf guide for homeowners. While you are there, pick up some soil-sampling kits. You can test now to determine the appropriate application rates for lime and fertilizer.*
Steve
Edit. Assuming Purdue provides soil-testing services.
I'm going to need to get some straw down. The trenches from last year's projects are bare and they are between the house and the woodpile.
I'll contact the local Purdue extension office for info.
Thanks!
2019 JOHN DEERE 5090M LOT NUMBER 92 (A53084)
2019 JOHN DEERE...
2019 Ram 5500 Dump Bed, VIN # 3C7WRNFL2KG599631 (A51572)
2019 Ram 5500 Dump...
100 Gal Fuel Tank with Pump (A51573)
100 Gal Fuel Tank...
2019 HYUNDAI HX300L EXCAVATOR (A51246)
2019 HYUNDAI...
BUSH HOG 2810CD SINGLE FLEX WING ROTARY MOWER (A51406)
BUSH HOG 2810CD...
