Winter Fuel
   / Winter Fuel #1
RobS
Super Member
Goshen, IN
None!
Is there such a thing as winter diesel fuel? If so, how do I know if that's what's at the local BP station? When do they changeover?
I just filled my tractor and emptied my yellow jug in doing so. I'm approaching the time of year when the tractor doesn't go through much fuel so what's in the tank will last until the snow flies probably. I do use PowerService in my fuel year 'round.
Should I wait to refill my yellow jug until I know the winter stuff is at the pump? Does it really matter? I do need the tractor in winter for snow removal and we see temps well below freezing up here /forums/images/graemlins/smile.gif
   / Winter Fuel #2
Ask the station owner. He should know if the last load was the winter blend or if the leftover in his tank was thinned with kerosene to make it winter blend.
When I had my station, any diesel delivered after late October was winter blend. My distrbutor always brought in a load af kerosene (amount depended on what was left in my storage tank) just before the winter blend became available.
   / Winter Fuel #3
They switch over from #2 to #1 when the ambient temps fall below 20*F. since the paraffins in #2 begin to gel and wax soon thereafter.
   / Winter Fuel #4
If you are at BP just look at the pump. Diesel is just #2, Premier and Power Blend are set for winter and have additives. Not all BP stations have all grades, some by me have only diesel while some a premium diesel pump. I use the Premier year round and done so for the past 30 years.
   / Winter Fuel #5
Get some Power Service and put about an ounce or two in the tank. This good to increase the cetane rating a couple of points and will also keep the fuel from gelling (if you're in a cold climate). If it gets really cold you can put a little extra in the tank ( I have a 17 gal tank and use this stuff all year down here in VA). A bottle will treat about 100 gallons. BobG in Va
   / Winter Fuel #6
</font><font color="blue" class="small">( A bottle will treat about 100 gallons )</font>
Depends on which size bottle your buy. /forums/images/graemlins/wink.gif I also used it year round and had farmer neighbors who bought it by the gallon, but I just dumped a pint in my 55 gallon barrel every time I filled it.
   / Winter Fuel #7
I purchased a quart bottle and it lasted me about 100 hours. I would just give it a "shot" whenever I filled the tank. I have never had any problems with my fuel gelling, and when I did run out, I could tell the difference in the sound of the engine. I just purchased a gallon at Wally World and that should get me through the winter... Junk.....
   / Winter Fuel #8
Power Service makes several diesel additive products. What is the full name of the product that you've used?
   / Winter Fuel #10
I just use the Power Service in the white quart plastic bottle. I believe they make their winter stuff for mostly anti-gel in the Silver bottle. I don't think it gets cold enough here in VA to have to go to the winter formual though. BobG in VA
2017 Chevrolet Silverado 3500 HD Crew Cab KUV Enclosed Service Truck (A52377)
2017 Chevrolet...
Case Wheels for Combine/Firestone Tires w/ extra rings NO RESERVE (A55301)
Case Wheels for...
JOHN DEERE ROW MARKERS - SET OF STACK FOLD 12 ROW 30 INCH ROW MARKERS (A55301)
JOHN DEERE ROW...
2006 Imperial 14Ft Flatbed T/A Equipment Trailer (A50324)
2006 Imperial 14Ft...
BUYERS PREMIUM & PAYMENT TERMS (A54313)
BUYERS PREMIUM &...
2021 CATERPILLAR 242D3 SKID STEER (A51406)
2021 CATERPILLAR...
