Winter Field Mowing
   / Winter Field Mowing #1
Hay Dude
Super Star Member
A Hay Field along the PA/DE border
Challenger MT655E, Massey Ferguson 7495, Challenger MT535B, Krone 4x4 XC baler, (2) Kubota ZD331’s, 2020 Ram 5500 Cummins 4x4, IH 7500 4x4 dump truck, Kaufman 35’ tandem 19 ton trailer, Deere CX-15, Pottinger Hay mowers
Anyone mowing brush, large fields in winter with frozen ground?
We have about 150 acres to cut when the ground freezes. Too soft/delicate to cut unless frozen.
We have one property with a few large retention pond basins we can only cut when the ground freezes.
Some areas overrun with blackberry
These were once hay fields, now contract cut Conservancy Lands.
Will add more with todays mowing. Gonna be low 20’s so great time to mow normally damp ground.
   / Winter Field Mowing #2
I have done some wintertime waterway mowing, frozen ground can be your friend.
   / Winter Field Mowing #3
I don't go out when it's that cold. 😜 I've been trying to cut since before Christmas but too wet/soft. I just got a new clutch for the brush mower I haven't even installed yet. Had to take it apart to clean the paint out of it. It was double dipped and stuck together. It was supposed to be pre-adjusted for 45hp but I doubt 100hp could break it loose.
It says to adjust by spring height but the free height of the springs are all different. How would that work? o_O
   / Winter Field Mowing #4
Doing rear implement work with the loader on would drive me absolutely nuts. If I'm not using the loader it's parked.
   / Winter Field Mowing #5
I hope to have something done also since it is frozen. They are going to look at it today and advise. Hope it goes well for you.
I love having a loader on in 8’ tall grass.
Works like a cow catcher for a locomotive sometimes. ;)
Also allows me to break off those pesky, cab destroying limbs. (y)
   / Winter Field Mowing #7
I just drop the bucket when not needed. No need to remove the loader.
   / Winter Field Mowing #8
LOL, I can take my loader off/on faster than I can remove/install the bucket or just as fast. Both have single point connectors and my loader is as easy as can be to connect and disconnect. With the loader on and a bush hog or finishing mower attached my tractor is so long and awkward that manuvering around is difficult. Bottom line is I just don't want it up there.
   / Winter Field Mowing #9
I've never removed the loader on my tractors unless a repair required it.
I do drop the bucket often to reduce the weight hanging off the front.
   / Winter Field Mowing #10
Ever since I ordered my cabbed tractor, I keep thinking of how productive I could be on those days that are too cold to do anything outside. I've tried bundling up, but it's just a matter of time until the cold works its way in, and then it becomes a test of how long I can last. Usually not very long!!!
2015 JLG 449 12ft Drop Deck Equipment Trailer (A51694)
2015 JLG 449 12ft...
2015 Ford F-750 Liftmoore 2550 5,000LB 2.5 Ton Crane Mechanics Truck (A51692)
2015 Ford F-750...
2016 FREIGHTLINER CASCADIA SLEEPER (A53426)
2016 FREIGHTLINER...
LINDE H80D FORKLIFT (A53843)
LINDE H80D...
2010 Hyundai Elantra Touring Sedan (A51694)
2010 Hyundai...
2000 Ford F-450 Service Truck (A51692)
2000 Ford F-450...
