Windows Virus affecting cd-rom's?
   / Windows Virus affecting cd-rom's? #1
Wingnut
Veteran Member
Mid-Michigan
Kubota L3710 GST
Windows Virus affecting cd-rom\'s?
Anyone heard of a virus that kills your cd-rom in Windows? I just suddenly noticed that my cd-rom was ignoring me ... it powers, is recognized by the system, Control Panel/System reports everything is ok ... but nothing will see the drive ... anything using explorer reports no media or invalid media in the drive.
I checked out Symantec and don't see anything about a virus or worm that hunts and destroys cd-roms ... but since TBN is usually ahead of the rest of the world, I thought I'd check here...
peter
   / Windows Virus affecting cd-rom's? #2
Re: Windows Virus affecting cd-rom\'s?
You may have a corrupted driver file or some such. You might try going into the device manager and deleting the device. Then restart. At boot up Windows should find the device, and install the drivers again (have your installation disks handy). An alternative is to use the system admin tool to check installed files, but that is a royal pain (lots of files tend to get replaced with questionable versions as Windows ages....)
   / Windows Virus affecting cd-rom's? #3
The best and fastest test is substitution of another CD-ROM drive...
If you can see the CD icon on the control panel and under system properties... normally the Win IDE devices/drivers will be ok and points to a defective laser/electronics CD hardware...
Besides CD's are dirt cheap... maybe replace it with a DVD for a few dollars more...? /w3tcompact/icons/smile.gif
   / Windows Virus affecting cd-rom's? #4
Sounds like defective hardware to me, too. These things just die for no reason and not all in the same manner. I wouldn't recommend a DVD-ROM drive unless you were actually planning on using it as DVD. I have an Afreey or Delta or some off-brand like that and it is sometimes very slow about reading the regular CD format, especially after a disc is first inserted.
   / Windows Virus affecting cd-rom's? #5
Wingnut,
Last time I saw that happen was on a friends computer. It just stopped reading the CDrom. Turned out that the CMOS battery was low. This allowed the BIOS to return to it's default setting which was for a SCUZZI drive. I reset the BIOS and everything was fine for a few days. Then the problem returned. Finally, we went to the local Hardware and bought a new battery.
SHF
   / Windows Virus affecting cd-rom's? #6
Wingnut,
I had a Kenwood 72X go flakey on me a month or so ago. It kinda acted funny for a couple of weeks and then - kaput. /w3tcompact/icons/mad.gif I tried the driver tricks, using a new channel cable, and switching the power cables. I just finally gave up and moved a spare CDROM from my other PC to replace the bad one. Screwed it in, connected the cables, turned on the PC, and everything was fine. /w3tcompact/icons/smile.gif
I vote for a bad CDROM. A new one will cost you anywhere from ~$25 - $100 depending on your level of pocketbook pain.
Terry
   / Windows Virus affecting cd-rom's? #7
Here's me being real simple - Have you tried a different CD?
   / Windows Virus affecting cd-rom's? #8
Just as an info only...not all CD-ROM drives will recognise a CD-RW disk...like it's not even there!
Although I also lean toward a dead drive, this might be something to think about.
Sigh .... well, looks like the consensus is harware ... which I hadn't really considered but will have to now look at. I hadn't even thought of swapping drives ... since this is a CD-RW that I only planted in there 2 months ago and haven't even used (to burn a coaster) yet.
But .... yeah, now that you ALL mention it ... it does sound like the obvious bet.
I just finished playing Lazarus with one of the other boxes that I'd kicked in frustration (I treat all computers extremely gently) so I could use it's CDRom as a mapped drive ... and installed the newest version of Norton ... and, of course, found no virii .... so .... I guess it's surgery time.
Oh well ... at 2 months, the drive should still be under warranty.
   / Windows Virus affecting cd-rom's? #10
I just went to the Windows Update web page and downloaded a new device driver that the site recommended (Intel Hdc Driver Version 2.0.0.2093) for my W98SE machine with a HP 8100 CD-RW. I downloaded and installed the driver, and suddenly my CD-ROM disappeared. The device drivers were loading on startup, but the P:/ drive disappeared from "My Computer", and I couldn't access the drive. I uninstalled the .dll file, and my CD-ROM has re-appeared.
2018 MACK CHU613 DAYCAB (INOPERABLE) (A53843)
2018 MACK CHU613...
TAKEUCHI TL150 SKID STEER (A51242)
TAKEUCHI TL150...
23169 (A50324)
23169 (A50324)
FRAME ONLY FRONT DISCHARGE CONCRETE TRUCK (A54313)
FRAME ONLY FRONT...
2018 CATERPILLAR 259D SKID STEER (A52705)
2018 CATERPILLAR...
BUYERS PREMIUM & PAYMENT TERMS (A54313)
BUYERS PREMIUM &...
