Will this work?
   / Will this work? #1
RickO
Central, Ohio
Kubota G1900
I just thought of a way to clean my mower deck that doesn't require crawling under. I want to fabricate a sort or a spray boom with three upward spraying nozzles that I could bury in the ground behind my barn. The nozzles would protrude out of the ground only an inch. When I want to clean the decks on my mowers I would drive them overtop the sprayers, one for each blade and hit the water and the blades of the mower to sling the grass off.
TSC has fittings you can put in you deck on the top to hook the water hose to and run your blades to do the same thing but I ain't drilling holes in my deck.
I think it would work but I'm a little worried about bearings getting water in them.
Your thoughts?
   / Will this work?
Actually it seems there is already something like it. Just did a search and found this.
Still I wonder would this hurt bearings?
Empire Products, Inc.
2012 INTERNATIONAL LF687 (A53843)
2012 INTERNATIONAL...
2010 DOOSAN G25 GENERATOR (A53843)
2010 DOOSAN G25...
ELECTRIC GOLF CART (A53843)
ELECTRIC GOLF CART...
JOHN DEERE 3020 TRACTOR (A51247)
JOHN DEERE 3020...
TOOTHED BUCKET ATTACHMENT FOR MINI EXCAVATOR (A53843)
TOOTHED BUCKET...
2004 CATERPILLAR 140H MOTORGRADER (A51406)
2004 CATERPILLAR...
