Will this work?
   / Will this work? #1
bones1
Platinum Member
St.Marys County. Maryland/Tall Timbers Md.
Farmtrac 300 dtc
/forums/images/graemlins/confused.gif Hello,great forum. I have a 300DTC and brush hog,loader,rake coming and was wondering if the brush hog can be used on a lawn as well.Never owning any of the above maybe someone could shed some light on this.Be nice if I could use it for both applications. Thanks a lot.
   / Will this work?
   / Will this work? #3
A brush hog will cut a lawn but it will be very cude compared to a finish mower. It tears the grass with big heavy blades while a finish mower cuts the grass with sharper blades turning at a highter speed generally. A finish mower usually has more wheels and rollers to keep from scalping also.
   / Will this work? #4
   / Will this work? #5
My neighbors property is 15 acres, not all grass of course but a rotary cutter is all that he has ever used even around the house. When we purchased our property we started cutting with a rotary cutter and switched to a finish mower once we got the wild stuff under control.
A finish mower will give you a better cut, but again some do use rotary cutters just the same.
   / Will this work? #6
   / Will this work? #7
Some people cut thier lawns with a rotart mower.. but you need to put just a bit of edge on them... works -ok-, tradeoff is the sharp blades suffer a tad when you hit rocks when you use it for rough cutting.
Soundguy
   / Will this work? #8
Soundguy
   / Will this work? #9
If you are calling it a lawn then a brush hog will not give you anything close to satisfaction. That is what a finish mower does. I tried doing the same thing several years back and the initial results were unsatisfactory until I purchased a caroni finish mower. It really depends on what kind of a look you prefer but brush hog and lawn sound kind of like sherman tank and race car!
   / Will this work? #10
2015 John Deere 5085M (A50120)
2015 John Deere...
KJ Double Ply Polyester Webbing Sling (A50121)
KJ Double Ply...
2013 Honda CR-Z EX Hatchback (A50324)
2013 Honda CR-Z EX...
NEW HOLLAND LB75B BACKHOE (A51242)
NEW HOLLAND LB75B...
2014 JOHN DEERE 544K LOADER (A51242)
2014 JOHN DEERE...
