Will this tractor move building?
   / Will this tractor move building? #1
robbyr
Veteran Member
western east central texas
ford and mahindra
We have a 14 x 32 metal building we're thinking bout moving from back yard to side yard. The tractor is a Mahindra 5570 70hp. The building has four 4 x 6 skids under it. Building is full of "stuff" such as tools and saddles. Wondering if I can drag it slowly with tractor? 0F5C3365-EC77-4D08-9912-8B7E44DD5A2B.jpeg
   / Will this tractor move building? #2
I moved a similar building on skids with a MF 135 once, it was a load for it.
I don't think you'll have any issues especially with some ballast in the FEL.
   / Will this tractor move building? #3
The tractor shouldnt be a issue but the strength of the building might. Adding extra weight to the floor and pulling at 1 point could damage the building. I see a tractor in the background that might help. Maybe add a pickup?
Good luck Pics too
   / Will this tractor move building? #4
Pulleys and cables can greatly increase the actual pulling force...it will basically come down to traction...
   / Will this tractor move building? #5
Yep it will move it
   / Will this tractor move building? #6
Can you put the tractor inside, support some with the FEL and support some with the 3pt using framework to trusses?
   / Will this tractor move building? #7
There is no doubt in my mind that the tractor will pull that building, especially if the tractor is ballasted. If the building is built strong enough and designed (chamfered skids) to be pulled. Might not hurt to spray some water in front of the skids to possibly reduce friction.
   / Will this tractor move building? #8
Don't pull with a V hook up. Put a spreader bar in, then do the V hookup.
   / Will this tractor move building? #9
It might be better in the long run though, if you took the time to empty out some of the heavier items first.
   / Will this tractor move building? #10
That seems like common sense.
2017 DRAGON PRODUCTS 130BBL VACUUM TRAILER (A53843)
2017 DRAGON...
Selco V5-HD Vertical Hydraulic Baler (A51691)
Selco V5-HD...
2007 Anderson 25ft T/A Flatbed Equipment Trailer (A51692)
2007 Anderson 25ft...
2005 Freightliner M2 106 Dumpster Carrier Truck (A51692)
2005 Freightliner...
2016 E-Z Beever M12R Towable Brush Chipper (A50322)
2016 E-Z Beever...
BUYERS PREMIUM & PAYMENT TERMS (A54313)
BUYERS PREMIUM &...
