Will this set up operate a hydraulic top link?
   / Will this set up operate a hydraulic top link? #1
Steve 3650
EAST CENTRAL IOWA
Mahindra 3650HST
I have a Mahindra 3650 that has 2 female quick couplers for rear remotes. They are labeled port A and port B. The valve associated with these ports is described as a single spool, double acting type hydraulic valve. Push the lever forward it supplies port A. Push it backward and it supplies port B. whenever the lever is released it returns to center position, called neutral. Is this an appropriate set up to operate a hydraulic top link?
   / Will this set up operate a hydraulic top link? #2
how does the fluid return to the tank ?
Good question. Maybe when the the handle returns to center? I obviously know very little about hydraulics. That is why I asked the question.
   / Will this set up operate a hydraulic top link? #4
Exactly what you need. When you plug the hoses of the cylinder into your couplers, make sure that when you move the lever forward, the cylinder retracts and when the lever is moved rearward, the cylinder extends.
Thank you very much az. That is exactly the response I was hoping for!
   / Will this set up operate a hydraulic top link? #6
That's what I've got. I marked the coupler and hose so I always put the hoses on the same ports.
   / Will this set up operate a hydraulic top link? #7
they sell color coated caps for both sides to keep it all straight when hooking up and removal.
Thanks for all your responses.
R&G Trailblazer 1000Gal 28% Applicator (A52349)
R&G Trailblazer...
2018 CHEVROLET 2500 SILVERADO (A52472)
2018 CHEVROLET...
2005 Mack CV713 Granite Truck, VIN # 1M2AG11C55M020965 (A51572)
2005 Mack CV713...
2017 Honda Civic Engine (A50325)
2017 Honda Civic...
