Loader Will the 45 loader fit the ultimate series X758 tractor?
   / Will the 45 loader fit the ultimate series X758 tractor? #1
cklawnnsnow
Ellsworth, pa
John Deere X320 X540
I just bought a new 2014 X758 4wd diesel with 54" HC deck, 54" plow and all and everything in between. I noticed when hooking up the hydraulics on the plow that there is no longer a big hole in the frame for the loaders attaching bar to go thru. has anyone any info on this or have tried to mount a 45 loader on the new x700 ultimate series tractors like mine, and if yes is there some sort of different kit or mount so you can?
   / Will the 45 loader fit the ultimate series X758 tractor? #2
You can probably work out the mounting issues with some fabrication work but these mowers are not offered with the 45 loader option now. New regulations caused Deere to drop this option on the mowers without a rops. I would be careful about adding this to a new mower as it will likely void the warranty too.
I purchased an x749 a few years ago and will add a 45 loader to it next year when it is out of warranty. While Deere does not recommend a loader on the 4ws models they can be made to fit, just have to be careful with sharp turns. Similarly the x758 can utilize the 45 loader but without the rops you have to be careful what you do with it.
If you knew you wanted a fel to start with the 1025R would have been a better choice.
HURRICANE 40' CONTAINER (A51248)
HURRICANE 40'...
2018 KENWORTH T370 T/A DUMP TRUCK (A51406)
2018 KENWORTH T370...
UNUSED RAYTREE RMBD72S-72" DRUM MULCHER (A51248)
UNUSED RAYTREE...
DEWALT 4400 PSI GAS PRESSURE WASHER (A51248)
DEWALT 4400 PSI...
AGT HPW3000-1 (A50123)
UNUSED KIVEL 3500# PALLET FORKS (A51248)
UNUSED KIVEL 3500#...
