Will TC 48/55 Rims fit a 2120?
   / Will TC 48/55 Rims fit a 2120? #1
shaley
Platinum Member
Tidewater VA.
Ford '92 2120
Hi, I have a 2120 MFWD that has turf tires and I want to go to industrials. Will the TC 48/55 rim bolt spacing fit my spindles?
Any ideas on how to do this switch.
   / Will TC 48/55 Rims fit a 2120? #2
According to a past post the 2120 has the same frame as the TC48/55. I would think the wheels are probably the same. I can measure the lug pattern on mine tomorrow and post here if no one has a positive answer before then.
I guess I will have to find original rims. Does anyone make these stateside. I bet shipping from Japan is a killer. Book shows a Frnt 8-18 R1 or 9.5-16. R1 Rear 13.6-28 R1 or 14.9-26 R1. I'm assuming you can put R4's on R1 rims? BTW what do those numbers mean?
   / Will TC 48/55 Rims fit a 2120? #5
The first number is the approximate tire width and the second is the rim diameter. I don't think you can find an industrial tire in the 16" diameter, I've only seen 16.5" diameter. I am not sure about the rear tires. There are a few places that make custom rims for specific bolt circles and rim sizes. They weld a center plate to the rim. You can mix and match front to rear tires as long as you keep the rolling circumference ratio between front and rear tires around 1.5:1 if it is 4 wd.
   / Will TC 48/55 Rims fit a 2120? #6
You can order the rims from you local New Holland dealer and just have them put your rims on their weekly stock order. It may take a week or two to get the rims but there is no freight charges on weekly stock orders, no matter how big the part or where it comes from. I would bet there are some in one of New Hollands warehouses in the US.
2025 12V Diesel Pump and Hose (A50324)
2025 12V Diesel...
UNUSED PALADIN SKID STEER HYDRAULIC BREAKING HAMMER (A51243)
UNUSED PALADIN...
2014 KOMATSU PC490 LC-10 CRAWLER EXCAVATOR (A52576)
2014 KOMATSU PC490...
6"x8' Treated Post,  Approx. 28 Piece Bundle  (A52384)
6"x8' Treated...
UNVERFERTH 330 - 22-INCH EXTENTSION TUBE FOR BASE AND WING ASSEMBLY FOR RIPPER (A53472)
UNVERFERTH 330 -...
20ft Driveway Gate (A51573)
20ft Driveway Gate...
