Will running a baler ruin my tractor?
   / Will running a baler ruin my tractor? #1
Anonymous Poster
Epic Contributor
I tried running my IH 37 baler on my Kubota L2550 (28 pto /30 engine hp) and it baled fine, I really couldn't notice any load on the engine, not even as much as running the backhoe, but I am worried that the constant load/no load on the pto. will wear something out, that baler is a very small model and is in good smooth operating condition so it has a small power requirement, the tractor pulls and stops it easilly, and it doesn't throw the tractor around, all I am concerned about is the pto. what is the weakest link in the pto? In other words, what will break or wear out first if something is going to go? I have a Farmall M that I could use, but it doesn't have brakes or live pto, which is a nuisance. Thanks for your help and opinions, Chris
   / Will running a baler ruin my tractor? #2
Your weakest point in the PTO SHOULD be the shear bolt which costs about $.20 and is what's supposed to go if you put too much load on the PTO. I'm surprised the baler runs as well as you describe. Usual minimum HP for a baler is around 40-45. 50-55 if you add a kicker. Maybe yours is a mini baler? Have you checked with the baler manufacturer and see what they reccomend as a minimum HP requirement?
   / Will running a baler ruin my tractor? #3
I run a NH 311 with a 30 pto hp L series Kubota with no problem. The baler is a regular sized square baler. Using the Kubota which is smaller than my Ford makes maneuvering in irregular spaces easier. Even though the Ford has twice the power of the Kubota, I'm probably going to sell it.
If you do overload the tractor, it will just stall the engine. You're not going to damage anything unless you transmit a severe shock load to the pto. Doesn't your baler have a slip clutch at the end of the drive shaft near the gear case? That should prevent any shocks to the drive line.
Most balers have a flywheel incorporated in the drivetrain to even out the little bumps in the pto load as the various mechinisms do their thing. Unless you see the driveline jumping around or notice heavy load fluctuations on the engine I don't think you have anything to worry about. I recommend keeping the rpms up to maintain 540 on the pto which is where the baler was intended to operate at.
   / Will running a baler ruin my tractor? #5
If a tractor encounters a severe/abrupt PTO load, the first thing that happens will be the engine rpms start dropping (this is where your engine torque curve comes into play), the more torque you have, the less the rpms drop, if the load is severe enough and the operator does nothing… then the engine will stall and go to “0” rpm. Usually it’s up to the operator to disengage the PTO prior to this point. If the load dissipates, then the engine rpm will increase as normal…Usually on balers, you will have multiple shear pins to prevent damage to the implement if it jams up… but you also have to “read” the sounds of the baler and know when to disengage the PTO… to correct any problems…
Normally, it’s not the PTO hp problem of running a baler… it’s a weight factor of towing a combined running baler and hay wagon… on a slight incline or side hilling you open yourself up for a very dangerous uncontrollable situation… “when the tail starts wagging the dog…”
Your average baler will weigh say between 3300-3800 lbs and the average 50-60 PTO hp tractor will weigh ~5000-7000 lbs… you can get into trouble rather quickly when the “tow vehicle” weighs less than the unit being towed… it’s a simple law of physics… /w3tcompact/icons/wink.gif
Loader Bucket (A50322)
Detach Trailer (A50514)
Detach Trailer...
1985 Toyota Pick Up Truck (A50515)
1985 Toyota Pick...
Toro Workman Low Profile Spray system 175 (A50322)
Toro Workman Low...
2009 Lee-Boy 8510HD Conveyer Feed paver (A52748)
2009 Lee-Boy...
2012 Ford F-250 4x4 Pickup Truck (A50323)
2012 Ford F-250...
