will not stay running
   / will not stay running #1
Mike B in Boise
mt.out side of boise
86 ford 1700 4x4
i have a 86 ford 1700 i replaced thermostat changed oil and replaced fuel filter now it will not stay running it will start and run for about 15 to 30 seconds then die. i have bled the line up to the injectors and i get fuel out of the bleed screw. i put a new battery in and it still runs like it is out of fuel. help.
   / will not stay running #2
If you take the fuel line off at the filter and drain it into a container, does fuel continue to flow?
   / will not stay running #3
deffinately sounds like fuel.. if it starts then dies.
soundguy
yes i get a flow of fuel i was able to get it to run for about 20 min. then when i powered it up it lost power a died. it would not restart felt loke the battery was dead. after waiting 30 min. it started again. it ran i powered it up and it dies again. as it runs it sounds louder than normal. it would also surge for a time it would idel up and down what do you think.
   / will not stay running #5
Still sounds like a fuel supply problem. Just run a temp line from the fuel tank filler opening to the filter inlet.
   / will not stay running #6
Ditto that. I know when my fuel tap gets plugged on my large diesels... they will usually start and run.. but starve out when i throttle them up as they use us more fuel than can pass the clog in the fuel tap..
soundguy
   / will not stay running #7
Did you install a new air filter, and did you check the intake duct to see if it was stopped up. I had a rat completely stop up my air intake one time with a nest, and caused all kinds of problems before it found it. It was in a curved section of the intake tube. Just something to think about
just came in and checked the site thanks for the ideas i will draine the tank and re check everything for ice or other obstructions. the air breather is a oil bath type. i chan ged the oil and checked for blocks its clear. i will ceek every one posted. and when i find the problem i will tel tou all. keep the ideas coming mike.
   / will not stay running #9
Does it have a fuel return line from the injector? If so it might be plugged.
   / will not stay running #10
I had one of those problems that drove me just about off the ledge with a fairly new JD.
It would fun fine idle all day, soon as I cracked her a bit it would start rattling. I took it to JD, was told it was an injector. I checked them all, no problem.
Did the fuel system, got flow everything seemed ok. Then I started to break it down piece by piece, fitting by fitting. What I found really got me going with JD.
The plastic-foam whatever float in the fueltank broke a small piece off and hung up in the 90 where the line goes into the filter.
2014 CATERPILLAR 303.5E CR EXCAVATOR (A52706)
2014 CATERPILLAR...
2025 Swict 84in Bucket Skid Steer Attachment (A53421)
2025 Swict 84in...
U56 ELECTRIC FIRE PUMP (A51406)
U56 ELECTRIC FIRE...
2018 MACK PINNACLE (A53843)
2018 MACK PINNACLE...
1982 GOOSENECK 24FT TRAILER (A52472)
1982 GOOSENECK...
2019 FREIGHTLINER CASCADIA TANDEM AXLE SLEEPER (A54607)
2019 FREIGHTLINER...
