Richard
Elite Member
- Joined
- Apr 6, 2000
- Messages
- 4,950
- Location
- Knoxville, TN
- Tractor
- International 1066 Full sized JCB Loader/Backhoe and a John Deere 430 to mow with
I'm presuming the answer is no....but here's the situation.
I have a 15' hydraulic flexwing mower. In each section of the mower is a (roughly) 4x6 inch hydraulic "cooling tank" that runs the entire length of the mower, front to back. The fluid route is sort of from main tank to blade 1, then into cooling tank on that wing, hose jumps it over to another cooling tank on the center portion of mower, at other end of this tank hose takes it to center blade.
Comes out of center blade pump, back into cooling tank that is now on the OTHER side of the main mower section, then crosses over to the last tank on the flex wing, then to third/final pump for 3rd blad, then back to main holding tank.
"or something similar to that"
Yesterday, was cutting a field when I turned and noticed a THIN stream of oil shooting up in air about two feet. (think of a childs squirt gun putting out a continous stream.....this is NOT a gusher but it is a leak)
Looks like it's right smack on top of the steel cooling tank.
Is this something that might be cleaned up, apply some JB weld and keep an eye on it? Would it be better to weld/braze the location (which would require me to drive machine several miles to shop)
I don't know the pressure in the tank....but I PRESUME since it's a closed loop system that it's ALL under high pressure but I admit to having no clue on high/low pressure zones.
I can't fathom how a hydraulic system could have sections of high/low pressure once the oil is beyond the hydraulic pump and prior to it reaching the main tank.
So let's presume this to be a high pressure system.
