Grading Will it fit, a 54" blade from a 4100 on my 2305?
   / Will it fit, a 54" blade from a 4100 on my 2305? #1
stuarth
Northern Ohio
Kubota BX2670
I am looking at a 54" snow blade on the web 300 miles away and the seller said it will fit a JD 4100, how would I know if this would fit my 2305? The picture looks like it has a hitch and blade. Thanks
   / Will it fit, a 54" blade from a 4100 on my 2305? #2
The only way to tell if it will work is to get measurments off both model tractors and the blade and see if they have the same mounting holes. I made up a custom front blade for my JD 3520 out of JD model 74 front blade. The blade is not listed to fit a 3520, but I measures a friends 4000 series tractor that had a model 74 on it. The 3520 had the same frame holes, so the mounting brackets worked.
   / Will it fit, a 54" blade from a 4100 on my 2305? #3
staurt, check out ebay item number 130044760170.Its a JD 54 inch blade and they list it as fitting both the model 4100 and 2305.
That is very interesting, I just bought my first JD coming from Kubota's and I can't seem to find any of this type of information other than asking. Thank you for the help.
   / Will it fit, a 54" blade from a 4100 on my 2305? #5
stuarth,
The blade is universal between machines (2210...2520), but the Quick hitch (what the blade is attached to) is different between a 4100 and 2305 (will not work unless seriously modified) been there done that and realized it was just going to be too much trouble and purchased a new quick hitch.
The 2210 and 2305 take the same quick hitch.
   / Will it fit, a 54" blade from a 4100 on my 2305? #6
I'm with JD2210 on this...
The blade will fit, but the QH will be different.
2019 Bobcat T770 Two Speed Compact Track Loader Skid Steer (A50322)
2019 Bobcat T770...
Ingersoll Rand 2570 Skidloader Breaker (A50774)
Ingersoll Rand...
2008 Ford F-250 Knapheide Service Truck (A50323)
2008 Ford F-250...
Caterpillar Loader Quick Coupler (A52748)
Caterpillar Loader...
1992 TIFF Motorhome (A50324)
1992 TIFF...
2018 JLG 10054 10,000LB 4x4 Rough Terrain Telehandler (A50322)
2018 JLG 10054...
