Will I be happy with 3t (6300-6500lb) vs 3.5t, homestead/occasional use machine?
   / Will I be happy with 3t (6300-6500lb) vs 3.5t, homestead/occasional use machine? #1
rice_harvester
new holland skid steer,
I am looking for ANY comments from more experienced operators about the specific capabilities of a ~6000lb (3ton) vs a ~7500lb (3.5ton) excavator. NOT on the jobsite but mainly for leisurely "hobby"/home use. I do my own maintenance/ mechanic so can evaluate used (older) equipment reasonably well. And despite the occasional use part, prefer to own vs rent due to remote location.
Current tilt trailer could haul a 7500lb+extras machine, I am looking for something to bumper pull not gn, in this case. I've been keeping my eyes out for a "deal" regionally and have yet to pull the trigger on anything in 2 years. I passed up a 'steal of a deal' Komatsu 6300lb 'feeling' it was way small at one point, but now ...
There is a low hours Hanix older 2.9ton (6500lb) machine, that has caught my interest.
The only similar thing I have ran personally, would be a kx71 rental years ago, about a 6500lb machine, which was capable enough but a little small for the road grading I was trying to use it for at that time, so my recollection is- underwhelming.
Brand names and specifics aside, would you try to talk me into ...or out of... the slightly smaller "3ton" , vs keep waiting for something slightly more "capable" to maybe come along eventually?
   / Will I be happy with 3t (6300-6500lb) vs 3.5t, homestead/occasional use machine? #2
Expand on your
I'm in about the same boat, right now I could use a "helping hand" picking up and moving 10' to 20' pine logs, about 20" in diameter (weight ~1,000 lbs).
   / Will I be happy with 3t (6300-6500lb) vs 3.5t, homestead/occasional use machine? #3
There just dont seem to be any "deals" on anything these days
   / Will I be happy with 3t (6300-6500lb) vs 3.5t, homestead/occasional use machine? #4
I have a 2ton and a 6ton machine. Always amazed what the 2tonner is capable of. A 3 tonner can do almost anything unless you need to lift larger boulders or something.
   / Will I be happy with 3t (6300-6500lb) vs 3.5t, homestead/occasional use machine? #5
I passed up a 2600 hr Cat 303.5 Cab at 9200 lbs as it was too big for what I needed and the attachments were very expensive. I did get a $11K 2 Ton China Mini Ex with Kubota engine instead (with a rock bucket, Auger, Tiling grading bucket)- its the helping hand loading 2' rocks into the FEL bucket, picking up logs etc. It's slow moving, and a bit on the light side.
IMO, a 6000-7000 lb machine is an ideal size for most tasks - as the 2 ton is too light for any serous trenching, boulder moving, stump removal.
My neighbor has the Cat 303.5 for sewer work, grading, general excavation, and that machine gets more hours than the big 315CAT. These 9000 lb machines like CAT or Bobcat e35 are workhorses that can do most everything well. It won't rip out 24" stumps like a 20T machine but it could.
   / Will I be happy with 3t (6300-6500lb) vs 3.5t, homestead/occasional use machine? #6
No,
Unless you want to just play in your backyard sand box, like small digging and trenching, anything less than a 5 ton machine will disappoint you.
   / Will I be happy with 3t (6300-6500lb) vs 3.5t, homestead/occasional use machine? #7
We use a Cat 302.5C at the farm for general maintenance type stuff and firewood. It is the perfect size / capacity for what we do. There hasn't been a farm task it wasn't up for, plenty of digging and lifting capacity. Hard to come by a good used Cat Machine at a decent price.
No,
   / Will I be happy with 3t (6300-6500lb) vs 3.5t, homestead/occasional use machine? #8
No,
In my experience this is not true at all and I have both a 2t and a 6t machine.
   / Will I be happy with 3t (6300-6500lb) vs 3.5t, homestead/occasional use machine? #9
rice_harvester,
Please pardon me but I'm thinking your asking the wrong question. What I don't see is what you want to accomplish and what is the best machine for the job. The best machine, once you have detailed your objectives may not be an excavator. Also, there is not much difference in machine capabilities of 6K vs 7.5K lb machines. Possibly a little more reach or lift at distance but not much. You won't see big differences until you double the machine weight, say going from 10K to a 20K lb machine or a 2K to 5K lb machine.
   / Will I be happy with 3t (6300-6500lb) vs 3.5t, homestead/occasional use machine? #10
Really depends on what you need to do, and the price difference. For stuff within the capability of a 2.5T machine, a 3.5T might not be faster or better; but work at the upper limits of a 3.5T or 5T machine, could take FAR longer with a 2.5T machine. There are two situations that I can think of that a 2.5T won't be able to handle with time: lifting things heavier than it has the butt for; ie, time doesn't overrule gravity. The 2nd is ground water; when you are trying to outdig ground water seepage, a small machine may not keep up with the water/sides falling in.
So, on machines; keep an eye for Yanmar, Ditchwitch, Veermer, Takekuki, and other real brands with less name recognition.
2017 FREIGHTLINER CASCADIA TANDEM AXLE SLEEPER (A52576)
2017 FREIGHTLINER...
2014 FREIGHTLINER 108SD WITH ELLIOT H110 CRANE/MANLIFT (A52472)
2014 FREIGHTLINER...
BW RVB3405 20,000lbs 5th Wheel Hitch Base (A50323)
BW RVB3405...
2012 LEEBOY 8515B APHALT PAVER (A51406)
2012 LEEBOY 8515B...
2008 Freightliner B2 School Bus (A51692)
2008 Freightliner...
LEGEND  2615 (15) BAT WING (A52472)
LEGEND 2615 (15)...
